Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Performance issue after EMF complex tree creation?(Performance issue)
Performance issue after EMF complex tree creation? [message #1744086] Thu, 22 September 2016 09:36 Go to next message
Jim 20100 is currently offline Jim 20100Friend
Member
I created an EMF model.
There are of course code to refresh some tree nodes when modifying values.
I use EContentAdapter to observe some modifications on my Model.
It is quite complexed.
I use as well EMF Form. Each time I click on a node, I displays a view:
myECPSWTView.dispose();
myECPSWTView = ECPSWTViewRenderer.INSTANCE.render(parent, myQuoteObject);
I use Jubula to create a complete model.
Or even if I create a full model manually, my eclipse is slower at each click.
Even if I close the EMF model, create a file is slow too.
I thought about memory issue, try to increase jvm settings.
I try to disable the EMF Form view.
For the moment, no results. Still slow after a model creation.
Do you have some way to check what is going on? for memory? etc.?
Re: Performance issue after EMF complex tree creation? [message #1744239 is a reply to message #1744086] Fri, 23 September 2016 14:43 Go to previous messageGo to next message
Eugen Neufeld is currently offline Eugen NeufeldFriend
Hi Jim,
can you show some code snippets, so that we see what exactly you are doing?
Can it be, that you add a econtentadapter every time you open you model without ever removing it?
why do you need the econtentadapter in the first place?
Eugen
Eugen Neufeld
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: Performance issue after EMF complex tree creation? [message #1744550 is a reply to message #1744239] Wed, 28 September 2016 07:39 Go to previous message
Member
Finally,
I found the reason.
It was not easy to find, but I did.
Thanks to the tool "Sleak", I was able to see that I instantiated Fonts for each cell.
So it stays always in memory, and my application performance suffered
progressively.
I was confident, but a bit stressed concerning performance.
Now everything is OK.
Thx
Rgds
Jim
Previous Topic:[ECP] Two Implementations Avoids IllegalArgumentException: The class ... is not a valid classifier
Next Topic:[EMF Forms] Filter TreeMasterDetail for predefined Elements
Current Time: Mon Sep 21 17:28:35 GMT 2020
Powered by FUDForum. Page generated in 0.03661 seconds
