Conflicts between identical handlers in Eclipse RCP [message #1744073] |
Thu, 22 September 2016 08:15 |
Vlad Acretoaie Messages: 95 Registered: April 2014 |
Member |
I am developing an Eclipse RCP application, and have recently started to see a very large number of console error messages regarding conflicting handlers, such as the following:
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:41.828
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.undo: {ActionHandler(org.eclipse.ui.operations.UndoActionHandler@7df5358)} vs {ActionHandler(org.eclipse.ui.operations.UndoActionHandler@7df5358)}
Status ERROR: org.eclipse.ui code=4 Conflicting handlers for org.eclipse.ui.edit.undo: {ActionHandler(org.eclipse.ui.operations.UndoActionHandler@7df5358)} vs {ActionHandler(org.eclipse.ui.operations.UndoActionHandler@7df5358)} null
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:42.625
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.redo: {ActionHandler(org.eclipse.ui.operations.RedoActionHandler@62ccbd95)} vs {ActionHandler(org.eclipse.ui.operations.RedoActionHandler@62ccbd95)}
Status ERROR: org.eclipse.ui code=4 Conflicting handlers for org.eclipse.ui.edit.redo: {ActionHandler(org.eclipse.ui.operations.RedoActionHandler@62ccbd95)} vs {ActionHandler(org.eclipse.ui.operations.RedoActionHandler@62ccbd95)} null
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:43.100
!MESSAGE Conflicting handlers for org.eclipse.jdt.ui.edit.text.java.open.editor: {ActionHandler(org.eclipse.jdt.ui.actions.OpenAction@135ddb56)} vs {ActionHandler(org.eclipse.jdt.ui.actions.OpenAction@135ddb56)}
Status ERROR: org.eclipse.ui code=4 Conflicting handlers for org.eclipse.jdt.ui.edit.text.java.open.editor: {ActionHandler(org.eclipse.jdt.ui.actions.OpenAction@135ddb56)} vs {ActionHandler(org.eclipse.jdt.ui.actions.OpenAction@135ddb56)} null
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:43.581
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:43.595
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.move: {ActionHandler(org.eclipse.ui.actions.MoveResourceAction@6859bbd4)} vs {ActionHandler(org.eclipse.ui.actions.MoveResourceAction@6859bbd4)}
Status ERROR: org.eclipse.ui code=4 Conflicting handlers for org.eclipse.ui.edit.move: {ActionHandler(org.eclipse.ui.actions.MoveResourceAction@6859bbd4)} vs {ActionHandler(org.eclipse.ui.actions.MoveResourceAction@6859bbd4)} null
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:44.015
!ENTRY org.eclipse.ui 4 4 2016-09-22 08:57:44.026
!MESSAGE Conflicting handlers for org.eclipse.ui.edit.rename: {ActionHandler(org.eclipse.ui.actions.RenameResourceAction@7d836c4a)} vs {ActionHandler(org.eclipse.ui.actions.RenameResourceAction@7d836c4a)}
Status ERROR: org.eclipse.ui code=4 Conflicting handlers for org.eclipse.ui.edit.rename: {ActionHandler(org.eclipse.ui.actions.RenameResourceAction@7d836c4a)} vs {ActionHandler(org.eclipse.ui.actions.RenameResourceAction@7d836c4a)} null
Notably, these are all platform-defined handlers and the conflicts appear to happen between each handler and itself, which is puzzling to say the least.
All errors appear when I click on entries in the Project Explorer view in my application. As I click around, the responsiveness of the Project Explorer degrades, up to the point where the context menu is no longer popping up.
My application is running in compatibility mode on version 4.5 of the Eclipse platform.
Another detail, which may or may not be relevant, is that I started seeing these messages after installing the VisualVM Eclipse plugin. I have uninstalled it, but still see the errors.
Thanks in advance!
Vlad
Re: Conflicts between identical handlers in Eclipse RCP [message #1744126 is a reply to message #1744073] |
Thu, 22 September 2016 14:14 |
Hi Vlad.
It is a puzzling problem, but I've been unable to reproduce the problem in my testing. But thank you for the insight that it's seen in the Project Explorer. Would you be able to share this application (email me)? I'd love to stomp this bug.
That said, it's a warning, not an error. Your functionality won't be compromised.
Brian.
FUDForum. Page generated in 0.03512 seconds
