WaitForComponent does not work [message #1743961] |
Wed, 21 September 2016 07:26 |
Jurjen Hofstra Messages: 65 Registered: March 2013 |
Member |
Hello Peoples,
We are using Jubula for 3 and a half years. But i never have seen the action 'WaitForComponent' working.
You specity a timeout, let's say 4000 miliseconds,
and you specify a delay, let's say 200 miliseconds.
But the timeout is never used: the actual wait is only 200 miliseconds (the delay time). the system does not wait for the component as i expect.
So i always have to add a ub_app_wait action. This because of the timeout Action Error which often occurs and should be prevented by the waitForComponent.
Strangely enough, i find nothing about this on this forum.
Do you have an idea about what is going wrong?
I am currently using Jubula 8.2.2.055, but also in older versions i never have seen the waitForComponent working.
Jubula is running on Windows 7 Professional.
I will add a screenshot showing the problem.
Many thanks in advance!!
Jurjen
[Updated on: Wed, 21 September 2016 07:31] Report message to a moderator
Re: WaitForComponent does not work [message #1744000 is a reply to message #1743991] |
Wed, 21 September 2016 11:52 |
Member |
Hi Alex,
In this specific case is the class i am trying to wait for is
com.trimergo.client.util.swingComponent.browse.BrowseTable
this class extends AbstractBrowseTable wich, in turn, extends JTable
im afraid that is the problem then. we dont use any toolkit, i just use Jubula with our Java application.
the components we use are home made components, built upon standard Java components.
so we should create our own Toolkit to solve this problem?
thanks!
Jurjen
[Updated on: Wed, 21 September 2016 11:52] Report message to a moderator
Re: WaitForComponent does not work [message #1746013 is a reply to message #1745872] |
Thu, 20 October 2016 12:32 |
Member |
Hi Alex,
I tried the waitForComponent in the DVDTool sample, but there i also can't get it working. The waitforcomponent only waits for the specified delay. The specified timeout is ignored. I added a screenshot so that you can see what is going on. What am i doing wrong?
thanks in advance!
kind regards
Jurjen
[Updated on: Thu, 20 October 2016 12:53] Report message to a moderator
FUDForum. Page generated in 0.03326 seconds
