How to handle dynamic parameter values using RCPTT ECL commands ? [message #1743821] |
Tue, 20 September 2016 02:37 |
surin komi Messages: 5 Registered: September 2016 |
Junior Member |
I need a mechanism to read parameter values(like type, index, text) from AUT after that i want to store the parameters and pass the same values into script during execution time.
Parameters:
after optional ControlHandler: Indicates the element after which the necessary element is present.
type optional String = "": Indicates the type of a control, if there are any types.
index optional Integer: Indicates the number of control in the list. If an element is first in the list, then this parameter is not present and the default is equal 0.
text optional String = "": Indicates the text\name of this element. This parameter is used by default, so -text word is not written at the recording of the test.
Please check the below script:
with [get-view Properties | get-section "" -index 1] {
get-combo -index 1 | select Date
get-combo -index 4 | select Integer
get-combo -index 7 | select Character
Here index values "index..." are dynamic. When i record and re run the same script , test case getting failed due to the dynamic index values.
Is there any method to read parameter values from AUT and pass the same values into script ?
So please suggest me if there any method to handle . Thanks in advance !
FUDForum. Page generated in 0.04307 seconds
