Re: Install for All Users [Enterprise Environment] [message #1743883 is a reply to message #1743770] |
Tue, 20 September 2016 11:39 |
Ed Merks Messages: 33141 Registered: July 2009 |
Yes, if Eclipse is installed somewhere that is read-only to the user, Eclipse will create a very small surrogate installation in the user's ~/.eclipse folder. Note that if you use the installer to create the installation, be aware that it uses a bundle pool by default and you should either turn off the use of the bundle pool, or find a good place (the default will not be good) for it , and it too should be read-only for the end user. It's particularly useful to use a bundle pool if you want to create multiple installations.
Note that users will be able to extend the basic installation by installing additional plugins which will then be located in the surrogate installation.
Ed Merks
FUDForum. Page generated in 0.05474 seconds
