Re: CDT + OpenOCD + GDB = not working [message #1749829 is a reply to message #1743823] |
Mon, 12 December 2016 23:01 |
Colin daly Messages: 7 Registered: December 2016 |
Hi there,
Having a difficult time getting the openOCD debugger to launch in a new setup. I am setting up openOCD and Eclipse on a new operating system, using a Nucleo F030R8 board that debugs fine on another system. When I launch the debugger in Eclipse I get the "error in final launch sequence":
Error in final launch sequence
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
localhost:3333: No such file or directory.
For what it's worth, I can run the debugger in terminal with ./openocd -f board/st_nucleo_f0.cfg and get:
GNU ARM Eclipse 64-bits Open On-Chip Debugger 0.9.0-00073-gdd34716 (2015-05-19-12:55)
Licensed under GNU GPL v2
For bug reports, read
openocd. org/doc/doxygen/bugs.html
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v25 API v2 SWIM v13 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 3.257369
Info : stm32f0x.cpu: hardware has 4 breakpoints, 2 watchpoints''
and the LED LD1 blinks alternatively green and red. Similarly, I can run External Tools in Eclipse just fine, but this doesn't open the debugger. So it seems like I'm close, but something isn't quite right. Let me know if you need any other details of my system.
Using:
Eclipse Mars.2 (4.5.2)
Mac 10.12.1
OpenOCD 0.10.0-201601101000-dev
GNU Tools gcc-arm-none-eabi-5_4-2016q3
FUDForum. Page generated in 0.03455 seconds
