Home » Archived » Jubula » testexec on Linux: NullpointerExecption while starting AUT
testexec on Linux: NullpointerExecption while starting AUT [message #1743251] Tue, 13 September 2016 10:42 Go to next message
I try to start an JavaFx application via testexec from Xubuntu on a VirtualBox Host.
First I've started the autagent on port 60001
./autagent -p 60001
Then the test:
./testexec -project V9_Tests -version 1.0 -testsuite V9_Tests -server localhost -port 60001 -autconfig aut_v9client@localhost -resultdir "/home/danny/jubula_8.3.0.122/examples/testresults" -dbscheme "Default Embedded (H2)" -dbuser sa -dbpw ""
9/13/16 11:01:40 AM - AUT Agent:	Connecting to "localhost:60001" ...
9/13/16 11:01:40 AM - AUT Agent:	connection established.
9/13/16 11:01:41 AM - Database:	Connecting as "sa" to "jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE"...
9/13/16 11:01:45 AM - Database:	Connection established.
9/13/16 11:01:45 AM - Database:	Loading project "V9_Tests" in version "1.0"...
9/13/16 11:01:46 AM - Database:	Project loading completed.
9/13/16 11:01:46 AM - Project:	Checking completeness
9/13/16 11:01:46 AM - Checking completeness of Test Suite "V9_Tests"...
9/13/16 11:01:46 AM - ... passed.
9/13/16 11:01:46 AM - AUT:		Starting AUT: "aut_v9client" via configuration "aut_v9client@localhost"...
!!Error occurred !!
	the communication between client and aut server could not established - AUTServer could not start: Unknown AUTServer exit code: 31.
 Picked up _JAVA_OPTIONS: "-javaagent:/home/danny/jubula_8.3.0.122/ite/plugins/org.eclipse.jubula.rc.common.agent_4.0.0.201607281404.jar"
	at org.eclipse.jubula.rc.common.AutServerLauncher.main(AutServerLauncher.java:96)
	at org.eclipse.jubula.rc.common.agent.RCAgent.premain(RCAgent.java:103)
	at sun.instrument.InstrumentationImpl.loadClassAndStartAgent(InstrumentationImpl.java:386)
	at sun.instrument.InstrumentationImpl.loadClassAndCallPremain(InstrumentationImpl.java:401)
	at org.eclipse.jubula.rc.common.AUTServer.sendExitReason(AUTServer.java:702)
	at org.eclipse.jubula.rc.common.AUTServer.start(AUTServer.java:402)
	at org.eclipse.jubula.rc.common.AUTServer.main(AUTServer.java:308)
	... 16 more
What can be the reason ?
Any ideas?
The application can be started manually without the autagent on that system.
Re: testexec on Linux: NullpointerExecption while starting AUT [message #1743293 is a reply to message #1743251] Wed, 14 September 2016 02:51 Go to previous messageGo to next message
Hi there,
thanks for the information. If you start the ITE on that system and try to start the AUT via the ITE, do you get the same error?
Alex
Re: testexec on Linux: NullpointerExecption while starting AUT [message #1743309 is a reply to message #1743293] Wed, 14 September 2016 05:14 Go to previous messageGo to next message
Hi Alexandra,
I tried that in the first place, but on this system I'm not able to open a test project in Eclipse, see Jubula on VirtualBox Linux (Xubuntu) - Endless Connecting to Database
Re: testexec on Linux: NullpointerExecption while starting AUT [message #1744371 is a reply to message #1743309] Mon, 26 September 2016 07:42 Go to previous messageGo to next message
However, I think that here at org.eclipse.jubula.rc.common.AUTServer.sendExitReason(AUTServer.java:702) a Null check is missing
protected void sendExitReason(String errorMessage, int exitCode) {
        try {
            m_iteCommunicator.send(new AUTServerStateMessage(
                    exitCode, errorMessage));
        } catch (CommunicationException ce) {
            log.error("Exception in start()", ce); //$NON-NLS-1$
On other spots in this class, m_iteCommunicator is being checked against Null and here it isn't
see https://github.com/eclipse/jubula.core/blob/master/org.eclipse.jubula.rc.common/src/org/eclipse/jubula/rc/common/AUTServer.java
Re: testexec on Linux: NullpointerExecption while starting AUT [message #1744411 is a reply to message #1743293] Mon, 26 September 2016 11:54 Go to previous message
Alexandra Schladebeck wrote on Wed, 14 September 2016 02:51
Hi there,
Alex
Hi Alex,
Yes, I see the same error in the eclipse environment on linux. As I said before I think, the NullPointerException should be avoided in the code.
index.php/fa/27211/0/
Previous Topic:Select entry by value doesn't work in 8.3 version
Next Topic:Migration to new "execute external command" step
Current Time: Sun Jul 13 23:59:59 EDT 2025
Powered by FUDForum. Page generated in 0.04028 seconds
