Home » Eclipse Projects » EGit / JGit » Incorrect log results after merge
Incorrect log results after merge [message #1743026] Fri, 09 September 2016 15:37 Go to next message
Denis Malyshkin is currently offline Denis MalyshkinFriend
Found a strange behavior (bug?) in a log command.
The corresponding test is attached.
It creates a repo, creates a branch, does some commits either to the created branch and to master, then merges master to the created branch. After merge it tries to calculate the number of commits between the branch and master. Because master has been already merged -- the branch is not behind the master, i.e. corresponding commit count should be 0. But 'Iterables.size' after a 'log' call returns the number of commits in the master minus 1.
Moreover, if 'sleep' in the line 43 is uncommented -- the bug will go away, and 'behind' is equal to 0.
What do I do wrong? Is it a bug in JGit library?
Re: Incorrect log results after merge [message #1743098 is a reply to message #1743026] Mon, 12 September 2016 09:10 Go to previous messageGo to next message
Christian Halstrick is currently offline Christian HalstrickFriend
Wow, that's an amazing bug. With your test program I can reproduce it most of the times. I created bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=501211 . Let's continue discussion in bugzilla
Ciao
Chris
Re: Incorrect log results after merge [message #1743128 is a reply to message #1743098] Mon, 12 September 2016 12:43 Go to previous messageGo to next message
Christian Halstrick wrote on Mon, 12 September 2016 09:10
I created bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=501211.
Thank you! Will wait for the fix.
Re: Incorrect log results after merge [message #1744383 is a reply to message #1743128] Mon, 26 September 2016 12:42 Go to previous message
Matthias Sohn is currently offline Matthias SohnFriend
fixed in JGit 4.5.0, see https://git.eclipse.org/r/81491
Previous Topic:How does Eclipse/eGit connect workspace to git repo and its project metadata/source files?
Next Topic:Cherry command available?
Current Time: Sun Jan 17 17:11:17 GMT 2021
Powered by FUDForum. Page generated in 0.01980 seconds
