Home » Newcomers » Newcomers » Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.common.types.util.FeatureOverridesSer(Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.common.types.util.FeatureOverridesService cannot be found by org.eclipse.emf.ecore.xcore_1.1.1.v20130903-0948)
Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.common.types.util.FeatureOverridesSer [message #1742646] Tue, 06 September 2016 10:37 Go to next message
Sachin Samaram is currently offline Sachin SamaramFriend
Can anybody tell me how to solve this issue?
at com.google.inject.util.Modules$RealOverriddenModuleBuilder$1.configure(Modules.java:152)
at com.google.inject.AbstractModule.configure(AbstractModule.java:59)
at com.google.inject.spi.Elements$RecordingBinder.install(Elements.java:223)
at com.google.inject.spi.Elements.getElements(Elements.java:101)
at com.google.inject.internal.InjectorShell$Builder.build(InjectorShell.java:133)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:103)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.createInjector(XcoreActivator.java:67)
at org.eclipse.emf.ecore.xcore.ui.internal.XcoreActivator.getInjector(XcoreActivator.java:55)
at org.eclipse.emf.ecore.xcore.ui.XcoreExecutableExtensionFactory.getInjector(XcoreExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$DeferredBuilderParticipant.initDelegate(RegistryBuilderParticipant.java:182)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$DeferredBuilderParticipant.getDelegate(RegistryBuilderParticipant.java:173)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$DeferredBuilderParticipant.getDelegate(RegistryBuilderParticipant.java:168)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$DeferredBuilderParticipant.build(RegistryBuilderParticipant.java:161)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:69)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:291)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:733)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:299)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:358)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:381)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
... 54 more
!ENTRY org.apache.log4j 4 0 2016-09-06 16:07:06.267
!MESSAGE org.eclipse.xtext.service.CompoundModule - Type org.eclipse.xtext.common.types.util.FeatureOverridesService not present
Re: Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.common.types.util.FeatureOverride [message #1742657 is a reply to message #1742646] Tue, 06 September 2016 12:56 Go to previous messageGo to next message
You're using a very old version of Xcore. It's not clear which version of Xtext you're using. Likely the two versions in not so compatible. Better would be to use the Neon versions of both these things.
Re: Caused by: java.lang.ClassNotFoundException: org.eclipse.xtext.common.types.util.FeatureOverride [message #1742674 is a reply to message #1742657] Tue, 06 September 2016 14:30 Go to previous message
I am using xtext 2.9. Can I upgrade xcore for xtext 2.9 in existing eclipse version?
Previous Topic:simple swing example fails within eclipse project
Next Topic:Eclipse not opening after being in use for over a week
Current Time: Mon Jan 27 05:21:44 GMT 2020
Powered by FUDForum. Page generated in 0.02685 seconds
