Home » Modeling » Ecore Tools » Illegal argument exception for "Name" property
Illegal argument exception for "Name" property [message #1742594] Tue, 06 September 2016 00:43 Go to next message
UmaShankar Subramani is currently offline UmaShankar SubramaniFriend
In my metamodel, the name is of String type.
I always see the "IllegalArgumentException" in the task bar, when I am in the property value box. I cannot name my objects at all.
I had same problem with the "ID" property, but then I changed the "ID-type" from String to Integer. Then it worked.
I do not know why I have this problem.
Please see the attached image.
Help me. Confused
  • Attachment: ecf.png
    (Size: 53.78KB, Downloaded 147 times)
Re: Illegal argument exception for "Name" property [message #1742616 is a reply to message #1742594] Tue, 06 September 2016 07:46 Go to previous message
Cedric Brun is currently offline Cedric BrunFriend
which datatype did you pick for the "name"' property exactly ? You should probably pick EString (and not "String") or EInteger (and not "Integer") which are supposed to be in the proposals.
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Previous Topic:Creating an "instance editor" ontop of ECore-model
Next Topic:EAttribute "ID" with Auto Increment
Current Time: Fri Jan 15 15:13:49 GMT 2021
Powered by FUDForum. Page generated in 0.03453 seconds
