Re: SaveComparisonModelAction enablement [message #1742509 is a reply to message #1742087] |
Fri, 02 September 2016 13:50   |
The comparison model has links towards the right and left model. We consider that if either of them is uneditable, there is a good chance that it is not reachable by regular means (model on a remote repository is the most frequent case). In such a case we do not want to save it as the user wouldn't be able to load it back.
You can contribute your own save action to have a different behavior if needed.
Laurent Goubet
Obeo
Re: SaveComparisonModelAction enablement [message #1743962 is a reply to message #1743869] |
Wed, 21 September 2016 07:29   |
You are right, there is no way to remove the default save button for now (at least, not iirc). If you are interested and find a clean way of enabling this for users of the API, do not hesitate to patch it and raise an enhancement request with that patch attached, we'll gladly look into it.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.02432 seconds
