Home » Eclipse Projects » e(fx)clipse » Problem with cssext.cssExtDsl
Problem with cssext.cssExtDsl [message #1742002] Wed, 21 August 2013 15:43 Go to next message
Aaron Schröder is currently offline Aaron SchröderFriend
Hello!
I am working on a project where we are producing an eclipse application (we are using e(fx)clipse as base) which actively uses xtext/xpand code generation and it has it's own code generation capabilities.
I am having problems with following exceptions that are occurring very often when I run our eclipse application, and I can't pinpoint what is the reason for this.
Also, inherited e(fx)clipse css editor is not "working" in our application, crashing with this exception:
org.eclipse.core.runtime.CoreException: Failed to create injector for at.bestsolution.efxclipse.tooling.css.CssDsl ExtensionFactory: at.bestsolution.efxclipse.tooling.css.ui.CssDslExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:57)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
Here is the stack trace, maybe someone can help me resolve this issue.
MANAGER: Ext Manager #1
0 [Worker-1] ERROR at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Failed to create injector for at.bestsolution.efxclipse.tooling.css.cssext.CssExtDsl
!ENTRY org.apache.log4j 4 0 2013-08-21 09:31:07.157
!MESSAGE at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Failed to create injector for at.bestsolution.efxclipse.tooling.css.cssext.CssExtDsl
10 [Worker-1] ERROR at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator - Guice creation errors:
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(Unknown Source)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.class(Unknown Source)
while locating org.eclipse.xtext.common.services.TerminalsGrammarAccess
for parameter 1 at at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess.<init>(Unknown Source)
at at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess.class(Unknown Source)
while locating at.bestsolution.efxclipse.tooling.css.cssext.services.CssExtDslGrammarAccess
while locating org.eclipse.xtext.IGrammarAccess
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.grammarAccess(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
while locating org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar
Caused by: org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:66)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.internalFindGrammar(TerminalsGrammarAccess.java:37)
at org.eclipse.xtext.common.services.TerminalsGrammarAccess.<init>(TerminalsGrammarAccess.java:33)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:84)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:54)
at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:53)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator.createInjector(CssExtDslActivator.java:67)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.CssExtDslActivator.getInjector(CssExtDslActivator.java:55)
at at.bestsolution.efxclipse.tooling.css.cssext.ui.internal.DefaultCssExtProvider.<init>(DefaultCssExtProvider.java:31)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:141)
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:139)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594)
at at.bestsolution.efxclipse.tooling.css.extapi.CssExt$OsgiCssExtServiceProvider.get(CssExt.java:48)
at at.bestsolution.efxclipse.tooling.css.extapi.CssExt$OsgiCssExtServiceProvider.get(CssExt.java:1)
at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:55)
at at.bestsolution.efxclipse.tooling.css.ui.internal.CssDslActivator.createInjector(CssDslActivator.java:67)
at at.bestsolution.efxclipse.tooling.css.ui.internal.CssDslActivator.getInjector(CssDslActivator.java:55)
at at.bestsolution.efxclipse.tooling.css.ui.CssDslExecutableExtensionFactory.getInjector(CssDslExecutableExtensionFactory.java:26)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:49)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:39)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:77)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:93)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:28)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl$1.getURI(Storage2UriMapperJavaImpl.java:217)
at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.handle(SourceAttachmentPackageFragmentRootWalker.java:279)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:100)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:88)
at org.eclipse.xtext.ui.resource.PackageFragmentRootWalker.traverse(PackageFragmentRootWalker.java:65)
at org.eclipse.xtext.ui.resource.SourceAttachmentPackageFragmentRootWalker.traverse(SourceAttachmentPackageFragmentRootWalker.java:168)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeData(Storage2UriMapperJavaImpl.java:230)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.getCachedData(Storage2UriMapperJavaImpl.java:169)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.updateCache(Storage2UriMapperJavaImpl.java:323)
at org.eclipse.xtext.ui.resource.Storage2UriMapperJavaImpl.initializeCache(Storage2UriMapperJavaImpl.java:357)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.load(AbstractBuilderState.java:61)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.ensureLoaded(AbstractBuilderState.java:68)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.getExportedObjects(AbstractBuilderState.java:177)
at org.eclipse.xtext.builder.impl.DirtyStateAwareResourceDescriptions.getExportedObjects(DirtyStateAwareResourceDescriptions.java:143)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.isDerived(DeltaConverter.java:192)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnit(DeltaConverter.java:164)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnits(DeltaConverter.java:254)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convertCompilationUnits(DeltaConverter.java:258)
at org.eclipse.xtext.common.types.ui.notification.DeltaConverter.convert(DeltaConverter.java:124)
at org.eclipse.xtext.builder.impl.javasupport.JavaChangeQueueFiller.elementChanged(JavaChangeQueueFiller.java:37)
at org.eclipse.jdt.internal.core.DeltaProcessor$4.run(DeltaProcessor.java:1682)
at org.eclipse.jdt.internal.core.DeltaProcessor.notifyListeners(DeltaProcessor.java:1672)
at org.eclipse.jdt.internal.core.DeltaProcessor.firePostChangeDelta(DeltaProcessor.java:1506)
at org.eclipse.jdt.internal.core.DeltaProcessor.fire(DeltaProcessor.java:1482)
at org.eclipse.jdt.internal.core.DeltaProcessor.resourceChanged(DeltaProcessor.java:2094)
at org.eclipse.jdt.internal.core.DeltaProcessingState.resourceChanged(DeltaProcessingState.java:470)
at org.eclipse.core.internal.events.NotificationManager$1.run(NotificationManager.java:291)
at org.eclipse.core.internal.events.NotificationManager.notify(NotificationManager.java:285)
at org.eclipse.core.internal.events.NotificationManager.broadcastChanges(NotificationManager.java:186)
at org.eclipse.core.internal.resources.SavedState.processResourceChangeEvents(SavedState.java:77)
at org.eclipse.jdt.internal.core.JavaModelManager$20.run(JavaModelManager.java:4943)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.jdt.internal.core.JavaModelManager$19.run(JavaModelManager.java:4935)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:182)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:26)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:52)
... 136 more
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2599)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2429)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1306)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1475)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:253)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 139 more
2) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'NOT_A_LINKwww.omg.org/XMI' not found. (classpath:/at/bestsolution/efxclipse/tooling/css/cssext/CssExtDsl.xmi, 2, 217)
for parameter 0 at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.<init>(Unknown Source)
at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.class(Unknown Source)
while locating org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry
while locating org.eclipse.jface.text.templates.ContextTypeRegistry
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.contextTypeRegistry(Unknown Source)
... 146 more
... 149 more
3) Error injecting method, java.lang.NullPointerException
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(Unknown Source)
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(LanguageRegistrar.java:45)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
3 errors
com.google.inject.CreationException: Guice creation errors:
Aaron Schröder, software developer
View 3 Realisierung Team
KEBA AG
Gewerbepark Urfahr 4041 Linz Austria
Re: Problem with cssext.cssExtDsl [message #1742003 is a reply to message #1742002] Wed, 21 August 2013 16:44 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Looks like the root problem you are having is that package Ecore-Package
"www.omg.org/XMI" is not found and because the CSS-Editor itself uses
the CSS-Ext language to define the possible css-properties, ... it will
fail as well.
Maybe someone on the xtext newsgroup can help us further? The
www.omg.org/XMI is the root namespace? Are you using a different version
of xtext? I ask because you mentionned xpand.
Tom
On 21.08.13 17:43, Aaron Schröder wrote:
> Hello!
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> 0 [Worker-1] ERROR
> !MESSAGE
> 10 [Worker-1] ERROR
> 2, 217)
> at
> Source)
> at
> Source)
> for parameter 1 at
> Source)
> at
> Source)
> while locating
> for field at
> Source)
> at
> while locating
> 2, 217)
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> 2, 217)
> at
> at
> at
> at
> at
> ... 136 more
> 2, 217)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> ... 139 more
> 2, 217)
> at
> Source)
> at
> Source)
> for parameter 1 at
> Source)
> at
> Source)
> while locating
> for parameter 0 at
> Source)
> at
> Source)
> while locating
> for field at
> Source)
> at
> while locating
> 2, 217)
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> 2, 217)
> at
> at
> at
> at
> at
> ... 146 more
> 2, 217)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> ... 149 more
> at
> Source)
> at
> while locating
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Method)
> Source)
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Problem with cssext.cssExtDsl [message #1742004 is a reply to message #1742002] Fri, 23 August 2013 19:46 Go to previous messageGo to next message
Hello Tom!
Thank you for your prompt answer. I have took a look at installed plugins because you have mentioned the version of xtext. Maybe a reason for these exceptions is the version of xtext that we updated... We are using e(fx)clipse 0.8.1. and we have upgraded xtext from 2.3.1 -> 2.4.2. My next step is going to be a downgrade to 2.3.1 (i don't remember why have we done this upgrade of xtext, maybe some other component we are using required it), and if this makes a difference I will let you know!
KEBA AG
KEBA AG
Re: Problem with cssext.cssExtDsl [message #1742006 is a reply to message #1742002] Sat, 24 August 2013 07:39 Go to previous messageGo to next message
Yes, migration to Kepler and latest e(fx)clipse is probably going to be the "golden" solution, as we are planing to switch our entire project to everything "latest" in the next month anyway :). I am glad that our problem occurs because we mismatched xtext version and nothing more sinister is behind it.
Thank you for all your help, if you are interested I can post how everything feels and works on Kepler and 0.9.0. on Monday?
KEBA AG
KEBA AG
Re: Problem with cssext.cssExtDsl [message #1742007 is a reply to message #1742006] Sat, 24 August 2013 09:43 Go to previous message
Sure - if you have problems just come back here.
Tom
Previous Topic:DnD support?
Next Topic:Missing OSGi-Bundle Dependencies
Current Time: Thu Jan 23 05:18:45 GMT 2020
Powered by FUDForum. Page generated in 0.02550 seconds
