Home » Eclipse Projects » DSDP - Real-Time Software Components (RTSC) » incorrect code generation for configuration.c file
incorrect code generation for configuration.c file [message #1741831] Tue, 30 August 2016 02:04 Go to next message
James Lockwood is currently offline James LockwoodFriend
Member
I am creating an Adc driver. Here is the relevant .xdc portion
    enum ClockSource_ {    // ADCCC register
        ClockSource_SYSCLK_And_ClockDivider = 0,  /*! SYSCLK And ClockDivider */
        ClockSource_ALTCLK = 1,                   /*! ALTCLK - Alternate Clock (16Mhz) */
        ClockSource_MOSC = 2                      /*! MOSC - Master Oscillator */
    enum HardwareAveraging_ {
        HardwareAveraging_None = 0x0,
        HardwareAveraging_2x   = 0x1,
        HardwareAveraging_4x   = 0x2,
        HardwareAveraging_8x   = 0x3,
        HardwareAveraging_16x  = 0x4,
        HardwareAveraging_32x  = 0x5,
        HardwareAveraging_64x  = 0x6
    enum VoltageReference_ {
        VoltageReference_VDDA_GNDA,
        VoltageReference_VREFA_GNDA
    struct SequencerInfo_ {
        UInt8              maxPositions;
        UInt32             interruptNumber;
        IInterrupts.IsrFxn isrFxn;
        UInt               priority;   // 0 = lowest priority, 3 = highest priority
    struct AdcModuleInfo_ {
        VoltageReference_  voltageReference;      // ADCCTL_VREF
        ClockSource_       clockSource;           // ADCCC_CS
        UInt8              clockDivider;          // ADCCC_CLKDIV
        UInt8              samplingLagInClocks;   // ADC_ADCSPC_PHASE
        HardwareAveraging_ hardwareAveraging;     // ADC_ADCSAC_AVG
        UInt32             baseRegisterAddress;
        SequencerInfo_     sequencerInfo[length];
    config AdcModuleInfo_ AdcModuleInfo[length];   // variable length.  one entry for each module.
My configuration file:
Adc = xdc.useModule('trust.drivers.ti.tm4c1294ncpdt.Adc');
Adc.AdcModuleInfo =
        {   // Module 0
            voltageReference:    Adc.VoltageReference_VDDA_GNDA,
            clockSource:         Adc.ClockSource_SYSCLK_And_ClockDivider,
            clockDivider:        1,
            samplingLagInClocks: 0,   // this affects the ADCSPC register to provide phase control
            hardwareAveraging:   Adc.HardwareAveraging_None,  // this affects the ADCSAC register
            baseRegisterAddress: 0x40038000,
            // sequencer settings (sequencer #0, 1, 2, 3)
            sequencerInfo: [
                        {   // Sequencer 0
                            maxPositions:    8,
                            interruptNumber: 14,
                            isrFxn:          Adc.module0Sequencer0IsrFxn,
                            priority:        0
                        {   // Sequencer 1
                            maxPositions:    4,
                            interruptNumber: 15,
                            isrFxn:          Adc.module0Sequencer1IsrFxn,
                            priority:        1
                        {   // Sequencer 2
                            maxPositions:    4,
                            interruptNumber: 16,
                            isrFxn:          Adc.module0Sequencer2IsrFxn,
                            priority:        2
                        {   // Sequencer 3
                            maxPositions:    1,
                            interruptNumber: 17,
                            isrFxn:          Adc.module0Sequencer3IsrFxn,
                            priority:        3
        {   // Module 1
            clockDivider:        1,
            baseRegisterAddress: 0x40039000,
            sequencerInfo: [
                        {   // Sequencer 0
                            maxPositions:    8,
                            interruptNumber: 46,
                            isrFxn:          Adc.module1Sequencer0IsrFxn,
                            priority:        0
                        {   // Sequencer 1
                            maxPositions:    4,
                            interruptNumber: 47,
                            isrFxn:          Adc.module1Sequencer1IsrFxn,
                            priority:        1
                        {   // Sequencer 2
                            maxPositions:    4,
                            interruptNumber: 48,
                            isrFxn:          Adc.module1Sequencer2IsrFxn,
                            priority:        2
                        {   // Sequencer 3
                            maxPositions:    1,
                            interruptNumber: 49,
                            isrFxn:          Adc.module1Sequencer3IsrFxn,
                            priority:        3
Here is the generated code which is incorrect:
/* --> trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_0_sequencerInfo__A */
const __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__0sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_0_sequencerInfo__A[] __attribute__ ((section (".rodata_trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_0_sequencerInfo__A")));
const __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__0sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_0_sequencerInfo__A[4] = {
        (xdc_UInt8)0x8,  /* maxPositions */
        (xdc_UInt32)0xe,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module0Sequencer0IsrFxn__I)),  /* isrFxn */
        (xdc_UInt)0x0,  /* priority */
    },  /* [0] */
        (xdc_UInt8)0x4,  /* maxPositions */
        (xdc_UInt32)0xf,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module0Sequencer1IsrFxn__I)),  /* isrFxn */
        (xdc_UInt)0x1,  /* priority */
    },  /* [1] */
        (xdc_UInt32)0x10,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module0Sequencer2IsrFxn__I)),  /* isrFxn */
        (xdc_UInt)0x2,  /* priority */
    },  /* [2] */
        (xdc_UInt8)0x1,  /* maxPositions */
        (xdc_UInt32)0x11,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module0Sequencer3IsrFxn__I)),  /* isrFxn */
        (xdc_UInt)0x3,  /* priority */
    },  /* [3] */
/* --> trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_1_sequencerInfo__A */
const __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__1sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_1_sequencerInfo__A[] __attribute__ ((section (".rodata_trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_1_sequencerInfo__A")));
const __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__1sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_AdcModuleInfo_1_sequencerInfo__A[4] = {
        (xdc_UInt32)0x2e,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module1Sequencer0IsrFxn__I)),  /* isrFxn */
    },  /* [0] */
        (xdc_UInt32)0x2f,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module1Sequencer1IsrFxn__I)),  /* isrFxn */
    },  /* [1] */
        (xdc_UInt32)0x30,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module1Sequencer2IsrFxn__I)),  /* isrFxn */
    },  /* [2] */
        (xdc_UInt32)0x31,  /* interruptNumber */
        ((xdc_Void(*)(xdc_Void))((xdc_Fxn)trust_drivers_ti_tm4c1294ncpdt_Adc_module1Sequencer3IsrFxn__I)),  /* isrFxn */
    },  /* [3] */
I can 'hack' it and make it compile by placing this in my Adc__epilogue.
#define __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__0sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_SequencerInfo_
#define __T1_trust_drivers_ti_tm4c1294ncpdt_Adc__1sequencerInfo trust_drivers_ti_tm4c1294ncpdt_Adc_SequencerInfo_
I seem to recall reporting something very similar awhile back which got fixed in subsequent releases of XDCTools. It was the same type of thing, but it affected the Module_State structure.
Re: incorrect code generation for configuration.c file [message #1741932 is a reply to message #1741831] Tue, 30 August 2016 16:32 Go to previous messageGo to next message
Sasha Slijepcevic is currently offline Sasha SlijepcevicFriend
James,
I'll look into it but can you let me know which version of XDCtools are you using?
Re: incorrect code generation for configuration.c file [message #1741950 is a reply to message #1741932] Tue, 30 August 2016 18:05 Go to previous messageGo to next message
Member
xdctools_3_32_00_0_06
I know there is one more newer, but looked at the release notes, and didn't see anything related to this, so I haven't tried it.
Do you want me to?
Thanks.
Re: incorrect code generation for configuration.c file [message #1742146 is a reply to message #1741950] Wed, 31 August 2016 18:16 Go to previous message
I don't think anything relevant changed in the meantime so the bug most likely still exists in newer tools.
Previous Topic:Can't locate source code while debugging GCC Arm device
Next Topic:news.eclipse.org is shutting down.
Current Time: Wed Dec 08 23:20:58 GMT 2021
Powered by FUDForum. Page generated in 0.01368 seconds
