Home » Newcomers » Newcomers » Cannot Find Eclipse Button Mac OSX(Problem)  () 1 Vote
Cannot Find Eclipse Button Mac OSX [message #1741801] Mon, 29 August 2016 17:30 Go to next message
Nathan Molby is currently offline Nathan MolbyFriend
So I have installed Eclipse twice, and both time Eclipse launches the first time without a problem. After I close it, however, I cannot find the button to open it again. It is not in my applications list and I cannot launch the program without installing the entire thing again. Thanks for your help!
Re: Cannot Find Eclipse Button Mac OSX [message #1741812 is a reply to message #1741801] Mon, 29 August 2016 19:41 Go to previous messageGo to next message
Tauno Voipio is currently offline Tauno VoipioFriend
Did you look in Launchpad (the icon with a rocket image)?
Tauno Voipio
Re: Cannot Find Eclipse Button Mac OSX [message #1741887 is a reply to message #1741812] Tue, 30 August 2016 12:34 Go to previous messageGo to next message
Nope, not there. I'm going to record my problem.
Ok so I recorded the problem and then in the record I actually found where it is located. Apparently Eclipse does not create an actual application so I had to search through all my files and find the executable. Then I just put that on my start menu so I can find it again.
Thanks!
Re: Cannot Find Eclipse Button Mac OSX [message #1741896 is a reply to message #1741887] Tue, 30 August 2016 13:53 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
If you used the installer, it showed you where the installation location would be and offered you the opportunity to change it.
index.php/fa/26924/0/
  • Attachment: installer.png
    (Size: 35.66KB, Downloaded 982 times)
Previous Topic:Error : while converting as Java project || Exception: Null Pointer Exception
Next Topic:Helios not starting
Current Time: Sun Jan 26 12:44:05 GMT 2020
Powered by FUDForum. Page generated in 0.03420 seconds
