Home » Newcomers » Newcomers » lerning namespaces (cpp)
lerning namespaces (cpp) [message #1741719] Sun, 28 August 2016 19:44 Go to next message
luu tecFriend
hi
im still in the learning process of cpp, todays work is to use namespaces.
the goal: define functions outside of a class, therefore, no object is needed to execute the function.
initial step (tutorial):
main.cpp:
namespace HWLib
  void Initialize(void);
void HWLib::Initialize(void)
  HAL_Init();
int main(void)
  /* Initialize HWLib */
  HWLib::Initialize();
works without any problem.
step 2: move into a separate source and header file:
main.cpp:
#include "HWLib.hpp"
int main(void)
HWLib.hpp
namespace HWLib
HWLib.cpp
  HAL_Init();
starts with: unknown type name 'namespace' and some other errors indicating missing line endings and brackets.
do you see the error?
Re: lerning namespaces (cpp) [message #1741724 is a reply to message #1741719] Sun, 28 August 2016 23:38 Go to previous message
luu tecFriend
CLOSED! Solution: Since it is a c/cpp project, somehow the gcc compiler was used for the namespace compilation instead of the g++.
Previous Topic:Exported Runable jar Problem
Next Topic:Side scroll in Logitech MX Master
Current Time: Sat Jan 16 00:55:59 GMT 2021
Powered by FUDForum. Page generated in 0.03338 seconds
