Home » Eclipse Projects » EGit / JGit » Reset to specified commit
Reset to specified commit [message #1741455] Thu, 25 August 2016 09:50 Go to next message
Vlad Acretoaie is currently offline Vlad AcretoaieFriend
Member
I'm using JGit to programmatically pull remote changes to a local repository. If the pull fails and throws an exception, I want to reset the local repository to the latest commit before the pull attempt.
However, the ResetCommand does not take a commit identifier as an argument, even though the Git reset command accepts a <commit> parameter. Is this a known limitation of the ResetCommand, or am I missing something?
Is there an alternative JGit command that I could use to the same effect?
Thanks in advance!
Vlad
Re: Reset to specified commit [message #1741764 is a reply to message #1741455] Mon, 29 August 2016 11:00 Go to previous messageGo to next message
Christian Halstrick is currently offline Christian HalstrickFriend
have you tried ResetCommand#setRef(myCommit.getName())... ?
Ciao
Chris
Re: Reset to specified commit [message #1741778 is a reply to message #1741764] Mon, 29 August 2016 13:16 Go to previous message
Member
Hi Christian,
Thank you for your answer.
I eventually did use ResetCommand#setRef(myCommit.getName()), but it took me some time to realize this would work. The API documentation for the setRef method seems a bit laconic.
Vlad
Previous Topic:Working with Multiple Repositories
Next Topic:Egit diff --git whitespace
Current Time: Mon Jan 27 18:12:58 GMT 2020
Powered by FUDForum. Page generated in 0.01676 seconds
