Default Editor [message #1741388] |
Wed, 24 August 2016 11:36 |
Despite a definition like this with default = "true" (in the plugin.xml file below):
<?xml version="1.0" encoding="windows-1252"?>
<?eclipse version="3.0"?>
<plugin>
<extension
point="org.eclipse.ui.editors">
<editor
class="com.infoly.eclipse.xtext.algo.ui.AlgorithmicExecutableExtensionFactory:org.eclipse.xtext.ui.editor.XtextEditor"
contributorClass="org.eclipse.ui.editors.text.TextEditorActionContributor"
default="true"
extensions="alg,algo"
id="com.infoly.eclipse.xtext.algo.Algorithmic"
name="Algorithmic Editor">
</editor>
</extension>
Le dialogue Preferenc affiche le dialogue suivant indiquant que l'éditeur par défaut Algorithmic n'est pas pris en compte, ce qui ce vérifie en ouvrant un fichier ]*.alg [/b]dans l'éditeur.
Why the default editor is not Algorithmic Editor but Text Editor?
The definition of the default editor in the code does not work, then it all worked fine with previous versions of eclipse a year or two).
FUDForum. Page generated in 0.24026 seconds
