Home » Modeling » EMF » Efficient check on EDataType(Trying to find out which EDataType you are dealing with)
Efficient check on EDataType [message #1740847] Thu, 18 August 2016 23:28 Go to next message
Johannes Gross is currently offline Johannes GrossFriend
I am parsing some JSON and putting it in a EMF based model, and for literals i have to distinguish to set them.
Currently i am doing:
if (type.getName().equals("Real")) {
        newobject.eSet(sf, Double.valueOf((String) ((JSONObject) je).get(property)));
} else if (type.getName().equals("Integer")) {
	newobject.eSet(sf, Integer.valueOf((String) ((JSONObject) je).get(property)));
} else {
	newobject.eSet(sf, ((JSONObject) je).get(property));
But i dont like it because string comparison is expensive and it should be an instanceof or equals object check. I could not get it to work however. EcorePackage.Literals.EString is just an int but not the type so i can't compare. As well as (type instanceof String) or EString didnt work for me. Any hints what the right approach is?
Joe
[Updated on: Wed, 24 August 2016 17:53]
Report message to a moderator
Re: Efficiant check on EDataType [message #1740872 is a reply to message #1740847] Fri, 19 August 2016 09:15 Go to previous messageGo to next message
Aurélien Mora is currently offline Aurélien MoraFriend
Member
Hello Joe,
I'm not sure to fully understand, what is your "type" variable ? an EMF object ? Anyway, if you want a quick comparison with no String, you probably should use an EEnum. You'll be able to use it like a java enum :
EType type = myObject.getType();
switch(type)
case INTEGER:
	break;
case REAL:
	break;
default:
	break;
[Updated on: Fri, 19 August 2016 09:56]
Re: Efficiant check on EDataType [message #1740882 is a reply to message #1740872] Fri, 19 August 2016 10:44 Go to previous messageGo to next message
It seems NNTP is broken so reposting this on the web forum.
Johannes,
Comments below.
So type here an an EDataType presumably.
> } else {
Well for Ecore you can assume identity. So testing type == XyzPackage.Literals.ABC is fine and of course highly efficient.
No, your confusing EcorePackage.ESTRING, which is an int with EcorePackage.Literals.ESTRING, which is an EDataType.
I think better would be to use EcoreUtil.createFromString(type, (String) ((JSONObject) je).get(property))) in all cases; the factory knows how to convert a literal to a value of the data type. Of course I don't understand if it will always be a String, i.e., without your model, I don't know which cases the final else covers.
> Joe
Ed Merks
Re: Efficiant check on EDataType [message #1741088 is a reply to message #1740882] Mon, 22 August 2016 22:21 Go to previous messageGo to next message
Hi Ed, Aurelien,
thanks for your input! This resolved the issue.
I forgot to mention that type is:
EDataType type = ((EAttribute) sf).getEAttributeType();
where sf is my StructuralFeature that i am currently working with.
So Ed, yes the EcoreUtil works fine and does what it should, however I still would like to understand why i can't:
EDataType myType = EcorePackage.Literals.ESTRING;
if (type instanceof myType) {
This gives me a compilation error: myType can't be resolved to a type.
Really weird. If i put the EcorePackage.Literals.ESTRING directly in the check, its the same error. This is only our of interest, so if you have an idea what the reason could be, let me know.
Joe
Re: Efficiant check on EDataType [message #1741110 is a reply to message #1741088] Tue, 23 August 2016 07:42 Go to previous messageGo to next message
Member
Actually, EcorePackage.Literals.ESTRING is not a type, it is an instance of EDataType, so you can't make an instanceof with that. If you need to make an instanceof, just use the interface EString.
But, in your example, both type and myType are not type of EStrings, they are EDataTypes. So I think the only comparison you can do is :
if (type == myType) {
[Updated on: Tue, 23 August 2016 07:53]
Re: Efficiant check on EDataType [message #1741204 is a reply to message #1741110] Tue, 23 August 2016 16:19 Go to previous message
Got it, thanks Aurelien!
Re: Efficiant check on EDataType [message #1741988 is a reply to message #1740847] Fri, 19 August 2016 05:18 Go to previous message
Johannes,
Comments below.
> } else if
> } else {
> Joe
Ed Merks
Previous Topic:check whether the model is loaded properly or not
Next Topic:Memory leak with EditingDomainActionBarContributor?
Current Time: Fri Dec 01 06:59:38 GMT 2023
Powered by FUDForum. Page generated in 0.02067 seconds
