Home » Newcomers » Newcomers » Fatal Error on Launch (Solaris 11)(Cannot launch Eclipse)
Fatal Error on Launch (Solaris 11) [message #1740828] Thu, 18 August 2016 18:14 Go to next message
Audrey Watson is currently offline Audrey WatsonFriend
I am fairly new to Solaris, so this is tricky. I have listed my eclipse.ini file, and attached the error I receive upon launch below.
eclipse.ini:
-startup
plugins/org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.solaris.sparcv9_1.1.300.v20160525-1303
-showsplash
org.eclipse.platform
--launcher.defaultAction
openFile
--launcher.appendVmargs
-exitdata
2000002
-vm
/usr/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.8
-Xms2048m
-Xmx4096m
Re: Fatal Error on Launch (Solaris 11) [message #1740851 is a reply to message #1740828] Fri, 19 August 2016 05:36 Go to previous messageGo to next message
Audrey,
This a Java core dump, perhaps caused by native GTK code in SWT. I
don't think the sparc arch is well supported and I believe support for
it will be dropped:
https://dev.eclipse.org/mhonarc/lists/cross-project-issues-dev/msg13344.html
> eclipse.ini:
> -startup
> --launcher.library
> -showsplash
> openFile
> -exitdata
> 2000002
> -vm
> /usr/bin/java
> -vmargs
> -Xms2048m
> -Xmx4096m
Re: Fatal Error on Launch (Solaris 11) [message #1741184 is a reply to message #1740851] Tue, 23 August 2016 14:54 Go to previous messageGo to next message
Ed,
Thanks for the response. That is understandable.
Do you know of any way of getting Eclipse up and running on this machine?
Thank you!
Re: Fatal Error on Launch (Solaris 11) [message #1741201 is a reply to message #1741184] Tue, 23 August 2016 16:10 Go to previous messageGo to next message
Sorry, I have no idea.
Re: Fatal Error on Launch (Solaris 11) [message #1741208 is a reply to message #1741184] Tue, 23 August 2016 16:45 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 08/23/2016 08:54 AM, Audrey Watson wrote:
> Ed,
> Thank you!
Audrey,
Google around for this. Over the years, I've seen Solaris discussed
discussed. It has been done.
Re: Fatal Error on Launch (Solaris 11) [message #1741209 is a reply to message #1741208] Tue, 23 August 2016 16:46 Go to previous messageGo to next message
Will do! Thank you both!
Re: Fatal Error on Launch (Solaris 11) [message #1744312 is a reply to message #1741209] Sat, 24 September 2016 19:01 Go to previous message
Andrew Glynn is currently offline Andrew GlynnFriend
A similar problem happened back with Ubuntu 13.10 and 14.04 The problem is discussed in this thread:
https://bugs.launchpad.net/ubuntu/+source/unity/+bug/1241101
I got Neon working under Solaris 11.3 by fudging the call specified in the debug log to use "" rather than null and recompiling SWT, however there should be a better way of fixing this - Eclipse SWT shouldn't be creating GTK widgets with null values since it will keep showing up on different calls with different versions of GTK.
Andrew Glynn
Previous Topic:Error Configuring "use google cloud sql instance" (App Engine SDK)
Next Topic:Problems installing eclipse neon
Current Time: Wed Jan 22 04:36:56 GMT 2020
Powered by FUDForum. Page generated in 0.04068 seconds
