Validating a weaving model programmatically [message #1740734] |
Wed, 17 August 2016 22:02 |
Leila S Messages: 36 Registered: January 2015 |
Member |
I want to validate a weaving model, which weaves two ecore metamodel. When I use the launch configuration there is no any problem. However, if I use java, the below error will be appeared.
Undefined variable, type or model: 'Source!EClass'
The minimal example is attached. Please run the validation.java file.
In the example:
GeneralTrace.ecore is the weaving metamodel.
TraceSMMtoTMM.model is the weaving model.
SourceMM.ecore is the source metamodel.
TargetMM.ecore is the target metamodel.
WeavingValidation.evl is the code written in evl for validating the weaving model.
The error is because of the sourceEndType constraint:
context GeneralTrace!TraceLinkEnd{
--TraceLinkEnd type must be set
constraint notEmptyLinkEndType{
check: self.type.isDefined
-- the type of SourceEnd must be related to one of Source meta-classes
constraint sourceEndType{
guard: self.satisfies('notEmptyLinkEndType') and self.sowner.isDefined()
check:Source!EClass.all.select(c|c.name = self.type.name).size() = 1
message: "The meta-class "+self.type.name+"SourceEnd refers to incorrect element"
I register three metamodels correctly but I don't know why the error occurs.
Bests,
Leila.
Attachment: TestEVL.zip
(Size: 15.17KB, Downloaded 104 times)
[Updated on: Wed, 17 August 2016 22:03] Report message to a moderator
Re: Validating a weaving model programmatically [message #1740976 is a reply to message #1740734] |
Mon, 22 August 2016 04:44 |
Hi Leila,
Injecting the following line of code just before the return statement in your "createEmfMetaModel" method should fix this.
emfMetaModel.getResource().getResourceSet().getPackageRegistry().put(EcorePackage.eINSTANCE.getNsURI(), EcorePackage.eINSTANCE);
Dimitris
FUDForum. Page generated in 0.02670 seconds
