Home » Newcomers » Newcomers » Eclipse Neon constantly freezing
Eclipse Neon constantly freezing [message #1740568] Mon, 15 August 2016 18:24 Go to next message
Luís de Sousa is currently offline Luís de SousaFriend
Eclipse Neon is freezing constantly, no more than two minutes after being started. There are no error messages or exceptions shown, the workbench simply stops responding. In the .log file are innumerate exceptions like the ones reproduced below.
What is causing this behaviour? Can it be fixed somehow?
Thank you.
!ENTRY org.eclipse.ui 4 4 2016-08-15 20:13:31.283
!MESSAGE Unable to create part
!SUBENTRY 1 org.eclipse.ui 4 0 2016-08-15 20:13:31.284
!MESSAGE
!SESSION 2016-08-15 20:13:47.804 -----------------------------------------------
eclipse.buildId=4.6.0.I20160606-1100
java.version=1.8.0_101
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.java.product
Command-line arguments:  -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.ui 4 0 2016-08-15 20:14:04.086
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (org.eclipse.swt.SWTError: No more handles [Browser style SWT.MOZILLA and Java system property org.eclipse.swt.browser.DefaultType=mozilla are not supported with GTK 3 as XULRunner is not ported for GTK 3 yet])
	at org.eclipse.swt.SWT.error(SWT.java:4533)
	at org.eclipse.swt.SWT.error(SWT.java:4448)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
	at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4528)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4146)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:687)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:604)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.swt.SWTError: No more handles [Browser style SWT.MOZILLA and Java system property org.eclipse.swt.browser.DefaultType=mozilla are not supported with GTK 3 as XULRunner is not ported for GTK 3 yet]
	at org.eclipse.swt.SWT.error(SWT.java:4559)
	at org.eclipse.swt.browser.MozillaDelegate.<init>(MozillaDelegate.java:57)
	at org.eclipse.swt.browser.Mozilla.create(Mozilla.java:667)
	at org.eclipse.swt.browser.Browser.<init>(Browser.java:99)
	at de.walware.ecommons.ui.mpbv.PageBookBrowserPage.createBrowser(PageBookBrowserPage.java:254)
	at de.walware.ecommons.ui.mpbv.PageBookBrowserPage.createControl(PageBookBrowserPage.java:242)
	at de.walware.ecommons.ui.mpbv.ManagedPageBookView.doCreatePage(ManagedPageBookView.java:294)
	at org.eclipse.ui.part.PageBookView.createPage(PageBookView.java:400)
	at org.eclipse.ui.part.PageBookView.partActivated(PageBookView.java:743)
	at de.walware.ecommons.ui.mpbv.ManagedPageBookView.newPage(ManagedPageBookView.java:509)
	at de.walware.statet.r.internal.ui.rhelp.RHelpView$1$1.run(RHelpView.java:192)
	at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
	at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
	... 24 more
!ENTRY org.eclipse.ui 4 0 2016-08-15 20:14:37.047
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:64)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:282)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:264)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:494)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:488)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:286)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:507)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:558)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:378)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:324)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:86)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1605)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1339)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1366)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1349)
	at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1378)
	at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.java:764)
	at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control.java:3457)
	at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Composite.java:801)
	at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:2000)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:5819)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5490)
	at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:9545)
	at org.eclipse.swt.widgets.Display.eventProc(Display.java:1275)
	at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
	at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2495)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:4141)
	at de.walware.ecommons.ui.mpbv.PageBookBrowserPage.setFocusToBrowser(PageBookBrowserPage.java:376)
	at de.walware.ecommons.ui.mpbv.PageBookBrowserPage.setDefaultFocus(PageBookBrowserPage.java:368)
	at de.walware.ecommons.ui.mpbv.PageBookBrowserPage$1.setFocus(PageBookBrowserPage.java:232)
	at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:1513)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$2.setFocus(ContributedPartRenderer.java:105)
	at org.eclipse.swt.custom.CTabFolder.setFocus(CTabFolder.java:2614)
	at org.eclipse.swt.widgets.Control.fixFocus(Control.java:217)
	at org.eclipse.swt.widgets.Control.setEnabled(Control.java:4567)
	at org.eclipse.ui.internal.WorkbenchWindow.disableControl(WorkbenchWindow.java:2113)
	at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2160)
	at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:293)
	at org.eclipse.ui.internal.SaveableHelper.runProgressMonitorOperation(SaveableHelper.java:271)
	at org.eclipse.ui.internal.SaveableHelper.saveModels(SaveableHelper.java:213)
	at org.eclipse.ui.internal.SaveableHelper.savePart(SaveableHelper.java:148)
	at org.eclipse.ui.internal.WorkbenchPage.saveSaveable(WorkbenchPage.java:3904)
	at org.eclipse.ui.internal.WorkbenchPage.saveEditor(WorkbenchPage.java:3918)
	at org.eclipse.ui.internal.handlers.SaveHandler.execute(SaveHandler.java:54)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:54)
	... 53 more
Re: Eclipse Neon constantly freezing [message #1740584 is a reply to message #1740568] Mon, 15 August 2016 21:09 Go to previous messageGo to next message
Luís,
Perhaps it's a problem with GTK 3 (are you on Ubuntu?) and this might help:
https://www.eclipse.org/forums/index.php/t/1071268/
> Thank you.
> !MESSAGE !SESSION 2016-08-15 20:13:47.804
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.lang.reflect.Method.invoke(Method.java:498)
> at
> at
> at
> at
> at
> at
> at
> at
> ... 24 more
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 53 more
Re: Eclipse Neon constantly freezing [message #1740651 is a reply to message #1740584] Tue, 16 August 2016 16:14 Go to previous message
I have modified the eclipse.ini file contents to what is reproduced below. However, the freezing continues.
Note also that I have no such issues with Eclipse Mars or Eclipse Luna.
Thank you.
-startup
plugins/org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.400.v20160518-1444
-product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
openFile
--launcher.appendVmargs
--launcher.GTK_version
2
-vmargs
-Dosgi.requiredJavaVersion=1.8
-XX:+UseG1GC
-XX:+UseStringDeduplication
-Xms256m
-Xmx1024m
Previous Topic:Edit readonly files
Next Topic:Tomcat can not be started via Eclipse and XAMPP
Current Time: Tue Feb 18 07:12:13 GMT 2020
Powered by FUDForum. Page generated in 0.07344 seconds
