Home » Modeling » M2T (model-to-text transformation) » Different behaviors in Eclipse and in Maven
Different behaviors in Eclipse and in Maven [message #1740225] Wed, 10 August 2016 14:37 Go to next message
Elie Richa is currently offline Elie RichaFriend
Member
My Acceleo generator project is behaving differently in Eclipse and in
Maven. The correct behavior is in Eclipse and I'd like to ensure that I
get the same behavior in Maven.
I suspected having different versions of Acceleo in Eclipse and in
Maven. The version in Eclipse is 3.6.4.201605040614.
So I added the same update site that I use in Eclipse as a repository in
Maven (http://download.eclipse.org/acceleo/updates/releases/3.6) and I
set the version of Acceleo to 3.6.4 in the pom.xml.
As a result, Maven did indeed download the same version as Eclipse,
3.6.4.201605040614, however I still got different behaviors.
I'm using the Equinox Acceleo launcher from Maven. How can I make sure
that the Eclipse instance used by the tycho-eclipserun-plugin is indeed
using the correct Acceleo version?
Elie
Elie Richa, Ph.D
Software Engineer, AdaCore
https://www.adacore.com
Re: Different behaviors in Eclipse and in Maven [message #1740298 is a reply to message #1740225] Thu, 11 August 2016 09:55 Go to previous message
Member
In fact I think I've found the answer.
The Equinox launcher relies on plugin manifests to determine which
dependencies it should install and load. So if I want a particular
Acceleo version to be used by the Maven Equinox launcher, I can specify
that version in my plugin's manifest. I haven't tried yet but I expect
this should work.
Elie
Elie Richa, Ph.D
Previous Topic:How Does Acceleo Know to Regenerate EMTL files?
Next Topic:Xpand and GMF
Current Time: Tue Apr 16 06:02:03 GMT 2024
Powered by FUDForum. Page generated in 0.23226 seconds
