Imposible to select the classes methods with Eclipse Neon JSDT [message #1740191] |
Wed, 10 August 2016 09:28 |
Xavier Ottolini Messages: 4 Registered: April 2016 |
I have just installed the latest Eclipse Neon JSDT edition. I have imported an old javascript project developped in Ecmascript 5. My project uses the asynchronous module definition API RequireJS to import sources.
When I open the Outline view, I see only the classes names but not the methods names. In the same way, when I press on Ctrl+O, I do not see any methods names. This is a problem because if I can not select directly the methods names I spend much more time.
Here is a example of class.
define([
"jquery",
"pubsub/pubsub",
"app/constant",
"app/utils/module-utils"
], function($, PubSub, constant, moduleUtils) {
"use strict";
* Constructor initializes variables
function Controller() {
var that;
that = this;
that.shown = false;
that.subscribers = [];
Controller.prototype.show = function() {
var that;
that = this;
that.shown = true;
Controller.prototype.hide = function() {
var that;
that = this;
that.shown = false;
return Controller;
Can someone tell me if there is a setting to allow to select the classes names ? Otherwise, is it necessary to download another plugin ?
Xavier
FUDForum. Page generated in 0.07807 seconds
