Re: Unable to Preference Synchronizer due to invalid password [message #1742043 is a reply to message #1740021] |
Fri, 12 August 2016 14:34 |
Hi Marcin,
You can change the user name and/or password in the Preferences -> General -> User Storage Service.
Cheers
/Eike
http://www.esc-net.de
Am 09.08.2016 um 05:01 schrieb Marcin Klopotek:
> I'm using Eclipse Preference Synchronizer to synchronize the settings on the new Eclipse installation. Unfortunately I
> have entered an incorrect password and now I'm unable to synchronize nor change the password to the correct one. I can
> see in the Error Log view that the password is incorrect
> org.eclipse.userstorage.util.ProtocolException: POST https://api.eclipse.org/api/user/login HTTP/1.1 403 : The
> username has not been activated or is blocked.
> at org.eclipse.userstorage.internal.Session$RequestTemplate.getStatusCode(Session.java:656)
> at org.eclipse.userstorage.internal.Session$RequestTemplate.authenticate(Session.java:471)
> at org.eclipse.userstorage.internal.Session$RequestTemplate.send(Session.java:396)
> at org.eclipse.userstorage.internal.Session.retrieveBlob(Session.java:226)
> at org.eclipse.userstorage.internal.StorageService.retrieveBlob(StorageService.java:273)
> at org.eclipse.userstorage.internal.Storage.retrieveBlob(Storage.java:369)
> at org.eclipse.userstorage.internal.Blob.getContents(Blob.java:108)
> at org.eclipse.oomph.setup.internal.sync.RemoteDataProvider.retrieve(RemoteDataProvider.java:89)
> at org.eclipse.oomph.setup.internal.sync.Snapshot.createWorkingCopy(Snapshot.java:110)
> at org.eclipse.oomph.setup.internal.sync.Synchronization.createWorkingCopy(Synchronization.java:152)
> at org.eclipse.oomph.setup.internal.sync.Synchronization.<init>(Synchronization.java:92)
> at org.eclipse.oomph.setup.internal.sync.Synchronizer.createSynchronization(Synchronizer.java:126)
> at org.eclipse.oomph.setup.internal.sync.Synchronizer.synchronize(Synchronizer.java:103)
> at org.eclipse.oomph.setup.internal.sync.SynchronizerJob.run(SynchronizerJob.java:144)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Is there a way to change the password somehow?
Cheers
/Eike
FUDForum. Page generated in 0.01430 seconds
