Home » Modeling » TMF (Xtext) » How to specify a super class in JvmInferrer(I want to generate a class with a super class, how do I do this with JvmModelInferrer?)
How to specify a super class in JvmInferrer [message #1739902] Fri, 05 August 2016 14:25 Go to next message
The "superTypes +=" generates an "implements" clause but I need an "extends" clause.
Which variable I can use for that?
Re: How to specify a super class in JvmInferrer [message #1739904 is a reply to message #1739902] Fri, 05 August 2016 14:41 Go to previous messageGo to next message
supertype += "m.Superclass".typeRef() does not work?
i which inferrer phase do you do that?
Re: How to specify a super class in JvmInferrer [message #1739908 is a reply to message #1739904] Fri, 05 August 2016 15:33 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 August 2016 10:41
1)
supertype += ...
Is unknown.
and
superTypes += ...
Does produce an "implements" clause.
2)
In the "isPreIndexingPhase = false" phase.
Re: How to specify a super class in JvmInferrer [message #1739912 is a reply to message #1739908] Fri, 05 August 2016 16:04 Go to previous messageGo to next message
i cannot reproduce this
domainmodelexample:
class DomainmodelJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	@Inject extension IQualifiedNameProvider
	def dispatch infer(Entity entity, extension IJvmDeclaredTypeAcceptor acceptor, boolean prelinkingPhase) {
		accept(entity.toClass( entity.fullyQualifiedName )) [
			documentation = entity.documentation
			superTypes += "demo.AbstractEntity".typeRef
Re: How to specify a super class in JvmInferrer [message #1739920 is a reply to message #1739912] Fri, 05 August 2016 17:05 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 August 2016 12:04
And what is the resulting class code ?
Re: How to specify a super class in JvmInferrer [message #1739921 is a reply to message #1739920] Fri, 05 August 2016 17:09 Go to previous messageGo to next message
import demo.AbstractEntity;
@SuppressWarnings("all")
public class Demo extends AbstractEntity {
Re: How to specify a super class in JvmInferrer [message #1739923 is a reply to message #1739920] Fri, 05 August 2016 17:12 Go to previous messageGo to next message
Olaf Bigalk wrote on Fri, 05 August 2016 13:05
Sorry, I tried again and now it works. Don't know why.
Thank you for your patiencs.
Re: How to specify a super class in JvmInferrer [message #1739929 is a reply to message #1739923] Fri, 05 August 2016 17:58 Go to previous messageGo to next message
I discoverd that the "superTypes +=" does not work correctly if the referenced type could not be found in the generators context.
May this be a bug ?
Re: How to specify a super class in JvmInferrer [message #1739932 is a reply to message #1739929] Fri, 05 August 2016 18:02 Go to previous messageGo to next message
> May this be a bug ?
What do you mean by generators context
Re: How to specify a super class in JvmInferrer [message #1740003 is a reply to message #1739932] Sun, 07 August 2016 19:20 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 05 August 2016 14:02
> May this be a bug ?
The context in which the generator runs including the generated classes.
Re: How to specify a super class in JvmInferrer [message #1740006 is a reply to message #1740003] Mon, 08 August 2016 03:43 Go to previous messageGo to next message
well this would mean you reference a class that does not exist right?
Re: How to specify a super class in JvmInferrer [message #1740041 is a reply to message #1740003] Mon, 08 August 2016 03:11 Go to previous messageGo to next message
Well Thats a Feature
Re: How to specify a super class in JvmInferrer [message #1740157 is a reply to message #1740006] Tue, 09 August 2016 21:18 Go to previous messageGo to next message
Christian Dietrich wrote on Sun, 07 August 2016 23:43
Yes, that means that non existent classes are considered to be interfaces - right ?
Re: How to specify a super class in JvmInferrer [message #1740171 is a reply to message #1740157] Wed, 10 August 2016 05:06 Go to previous message
Yes
Previous Topic:rootPath, alternative folder layouts and maven build
Next Topic:How to generate a method with a throws clause
Current Time: Mon Feb 17 13:19:43 GMT 2025
Powered by FUDForum. Page generated in 0.04523 seconds
