install problems [message #1739767] |
Thu, 08 August 2013 12:31 |
I try to install efxclipse 0.8.1 into Kepler (4.3.0 I20130605-2000) but i still get these errors:
Cannot complete the install because one or more required items could not be found.
Software being installed: e(fx)clipse - All in One 0.8.1.201303200240 (at.bestsolution.efxclipse.feature.feature.group 0.8.1.201303200240)
Missing requirement: Jemmy 0.8.1.201303112105 (at.bestsolution.efxclipse.runtime.jemmy 0.8.1.201303112105) requires 'bundle org.junit4 4.8.1' but it could not be found
Missing requirement: Jemmy 0.8.1.201303200240 (at.bestsolution.efxclipse.runtime.jemmy 0.8.1.201303200240) requires 'bundle org.junit4 4.8.1' but it could not be found
Cannot satisfy dependency:
From: e(fx)clipse - All in One 0.8.1.201303200240 (at.bestsolution.efxclipse.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.tooling.feature.feature.group [0.8.1.201303200240]
From: e(fx)clipse - Jemmy FX to Junit Test OSGi-Apps 0.8.1.201303112105 (at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1.201303112105)
To: at.bestsolution.efxclipse.runtime.jemmy [0.8.1.201303112105]
From: e(fx)clipse - Jemmy FX to Junit Test OSGi-Apps 0.8.1.201303200240 (at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.runtime.jemmy [0.8.1.201303200240]
From: e(fx)clipse - Composite - FX Tooling 0.8.1.201303200240 (at.bestsolution.efxclipse.tooling.feature.feature.group 0.8.1.201303200240)
To: at.bestsolution.efxclipse.runtime.jemmy.junit.feature.feature.group 0.8.1
Running Kepler (64Bit) on Win7 (64Bit) with JDK 1.7u25 (64Bit) and I used these update sites:
http://www.efxclipse.org/p2-repos/nightly/site/
http://downloads.efxclipse.org/p2-repos/releases/latest/
both with same results.
I also tried to install only "e(fx)clipse - Composite - FX Tooling 0.8.1.201303112105" but it ended in the same result.
Is there something broken? Should I use other update sites?
I appreciate any help.
Thanks...
FUDForum. Page generated in 0.03454 seconds
