Running ESH on Knoplerfish framework [message #1739698] |
Thu, 04 August 2016 04:59 |
Dae-myeong Kang Messages: 2 Registered: July 2016 |
Hi!
I've tried to run ESH on the several OSGi frameworks(Equinox, Felix, Concierge, Knoplerfish...), and it runs on Equinox & Felix perfectly, but in Knopflerfish, some bundles(io.rest, jaxrs.publisher) don't work with following messages:
<org.eclipse.smarthome.io.rest_0.8.0.b5.jar>
> [stderr] ## DEBUG: errors - FrameworkErrorEvent bundle #79
[stderr] ## DEBUG: errors - FrameworkErrorEvent throwable:
[stderr] org.osgi.framework.BundleException: Bundle#79, unable to resolve: Missing package(s) or can not resolve all of the them:
org.eclipse.smarthome.core.types -- Provider rejected because of uses directive - org.eclipse.smarthome.core.types Bundle[id=68,gen=0].
org.eclipse.smarthome.core.library.types -- Provider rejected because of uses directive - org.eclipse.smarthome.core.library.types Bundle[id=68,gen=0].
org.eclipse.smarthome.core.library.items -- Provider rejected because of uses directive - org.eclipse.smarthome.core.library.items Bundle[id=68,gen=0].
org.eclipse.smarthome.core.items -- Provider rejected because of uses directive - org.eclipse.smarthome.core.items Bundle[id=68,gen=0].
org.eclipse.smarthome.core.events -- Provider rejected because of uses directive - org.eclipse.smarthome.core.events Bundle[id=68,gen=0].
com.google.common.collect -- Provider rejected because of uses directive - com.google.common.collect;version=15.0.0 Bundle[id=42,gen=0].
com.google.common.base -- Provider rejected because of uses directive - com.google.common.base;version=15.0.0 Bundle[id=42,gen=0].
[stderr] at org.knopflerfish.framework.BundleImpl.getUpdatedState(BundleImpl.java:1259)
[stderr] at org.knopflerfish.framework.BundleImpl.finalizeActivation(BundleImpl.java:312)
[stderr] at org.knopflerfish.framework.PermissionOps.callFinalizeActivation(PermissionOps.java:265)
[stderr] at org.knopflerfish.framework.BundleImpl.start(BundleImpl.java:295)
[stderr] at org.knopflerfish.bundle.desktop.swing.Desktop$36.run(Desktop.java:2666)
<com.clipsesource.jaxrs.publisher_5.3.1.201602281253.jar>
[stderr] org.osgi.framework.BundleException: Bundle#89, unable to resolve: Missing package(s) or can not resolve all of the them:
org.glassfish.jersey.servlet;version=[2.3.0,3.0.0) -- Uses directive block - org.glassfish.jersey.servlet;version=2.22.2 Bundle[id=57,gen=0].
org.glassfish.jersey.server;version=[2.3.0,3.0.0) -- Provider rejected because of uses directive - org.glassfish.jersey.server;version=2.22.2 Bundle[id=57,gen=0].
org.glassfish.jersey.internal;version=[2.3.0,3.0.0) -- Uses directive block - org.glassfish.jersey.internal;version=2.22.2 Bundle[id=57,gen=0].
I can see these packages in smarthome.core & jersey-all and they are active. But the io.rest & jaxrs.publisher can't load these packages.
I really wonder why it doesn't work on the Knoplerfish...
[Updated on: Thu, 04 August 2016 05:47] Report message to a moderator
FUDForum. Page generated in 0.03027 seconds
