Home » Eclipse Projects » OM2M » om2m and Iot(om2m and Iot)
om2m and Iot [message #1739587] Wed, 03 August 2016 07:18 Go to next message
soumya patra is currently offline soumya patraFriend
Hi all,
I am developing IoT solution and now i want that to be OM2M std.
Before that I want some clarification,
1) what is the difference between OM2M and ONEM2M.
2)If i have a Temperature Sensor and want to do OM2M implementation on board and gateway, how can i proceed.
3)Which industry/domain are using OM2M for their product.
Thank you Smile
Re: om2m and Iot [message #1739723 is a reply to message #1739587] Thu, 04 August 2016 10:10 Go to previous messageGo to next message
Dorian Kurzaj is currently offline Dorian KurzajFriend
1) OM2M is not a standard, it is an implementation of the oneM2M standard.
2) You should run an IN (Infrastructure Node) as the "root" of your system. Then run an MN (Middle Node) which is going to register to the IN previously created. And after that, you will have to register your Temperature Sensor to this MN as a new AE (Application Entity). In order to communicate to between your sensor and OM2M you have to create an IPE (Interworking Proxy application Entity) such as described in this tutorial : https://wiki.eclipse.org/OM2M/one/Developer
3) I can't answer that, sorry
Dorian Smile
[Updated on: Fri, 05 August 2016 09:30]
Report message to a moderator
Re: om2m and Iot [message #1739851 is a reply to message #1739723] Fri, 05 August 2016 04:14 Go to previous messageGo to next message
Hi Dorian
Thanks a lot for the reply. I will follow the steps.
If i have some doubt i will get back to you.
Thanks and Regards
Soumya Smile
Re: om2m and Iot [message #1739877 is a reply to message #1739851] Fri, 05 August 2016 09:36 Go to previous messageGo to next message
Ok Smile
Oh, and maybe this page can answer your third question : https://wiki.eclipse.org/OM2M/Community. I don't know if it is exhaustive but it can give you an idea.
Dorian
Re: om2m and Iot [message #1765303 is a reply to message #1739877] Thu, 08 June 2017 09:32 Go to previous messageGo to next message
Devang Zalavadiya is currently offline Devang ZalavadiyaFriend
Dear soumya patra,
I am very new in OM2M, I am doing the same like you. I have connected Temperature sensor and current sensor with Arduino and sending the measurement data to local server as MQTT messages. could you tell me what you did after this how did you connected your sensor with OM2M ?
Thank you..!!
Re: om2m and Iot [message #1775124 is a reply to message #1765303] Wed, 25 October 2017 03:37 Go to previous message
Umar Farooq is currently offline Umar FarooqFriend
Dear all,
I am also working on an om2m project and would like to know how can sensor nodes be connected to the IoT gateway (om2m). I know Dorian shared a useful link which uses plugins (thank you), but is there any other resource which can be helpful?
thanks
Previous Topic:Announced Resources handle in remote located IN-CSE
Next Topic:raspberry as gateway
Current Time: Wed Apr 01 10:51:31 GMT 2020
Powered by FUDForum. Page generated in 0.01900 seconds
