Home » Modeling » Compare » Undo Redo Functionality Not working in EMF Compare in Dialog(Undo Redo Functionality Not working in EMF Compare in Dialog)
Undo Redo Functionality Not working in EMF Compare in Dialog [message #1739585] Wed, 03 August 2016 07:10 Go to next message
Gaurav Tripathi is currently offline Gaurav TripathiFriend
Member
I am comparing two model using EMF Compare in Dialog and not Editor. After doing one or more merging from right to left when I do ctrl+z it's not working.
May I know the reason why it's not working ?
Any help is appreciated.
Thanks in advance.
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1740610 is a reply to message #1739585] Tue, 16 August 2016 08:15 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
Do you have anything in the error log when trying to reproduce this?
Laurent Goubet
Obeo
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1740977 is a reply to message #1740610] Mon, 22 August 2016 05:07 Go to previous messageGo to next message
Member
Hi Laurent,
It's not showing any error in error log.
But when I am trying to print the value of getCommandStack().canUndo(), it is printing false.
Thanks.
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1741490 is a reply to message #1740977] Thu, 25 August 2016 14:04 Go to previous messageGo to next message
The undo action is never called from the dialog, but I have no idea why since it's properly created and made enabled. Could you raise this issue on the bugzilla?
Laurent Goubet
Obeo
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1743324 is a reply to message #1741490] Wed, 14 September 2016 11:47 Go to previous messageGo to next message
Member
Hi Laurent,
It's already raised.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=480400
It's not fixed yet.
Gaurav
Re: Undo Redo Functionality Not working in EMF Compare in Dialog [message #1743711 is a reply to message #1743324] Mon, 19 September 2016 07:45 Go to previous message
Hi, and sorry, didn't find that with a quick search so I guess I was using wrong filters.
It is not fixed yet because the compare dialog isn't a priority of us for now. We'll gladly welcome contributions if you're willing to try and fix this issue, but investigations are not planned on our side to get this to work.
Laurent Goubet
Obeo
Previous Topic:EMF Compare 3.2 compatibility
Next Topic:Elements matching order
Current Time: Sun Sep 19 02:22:23 GMT 2021
Powered by FUDForum. Page generated in 0.01644 seconds
