Home » Newcomers » Newcomers » Eclipse crashes when attempting to load Lynda's exercise files
Eclipse crashes when attempting to load Lynda's exercise files [message #1739249] Thu, 28 July 2016 21:02 Go to next message
Roy Keret is currently offline Roy KeretFriend
Hi, I'm attempting to learn basic Java using a Lynda course. (Up and Running with Java Applications)
Per the course's instructions, I've navigated to oracle.org and searched for 'Eclipse IDE for Java Developers'
Got as far as this page:
<eclipse>/downloads/download.php?file=/technology/epp/downloads/release/kepler/SR1/eclipse-java-kepler-SR1-linux-gtk-x86_64.tar.gz
Where every download link is broken. so I've traverse up in the folder hierarchy to find that apparently the hierarchy changed from "SR1" to "SR2".
Downloaded and extracted "eclipse-java-kepler-SR2-linux-gtk-x86_64.tar.gz"
Specified Oracle's JDK in eclipse.ini
OS: CrunchBang Linux x64
JDK: Oracle JDK 1.8.0_101 X64
Everything seems to work, but when I import Lynda's workspaces (according to the exact course instructions) Eclipse's crashes..
Log's attached..
Would appreciate any lead.. Smile
  • Attachment: 0.log
    (Size: 10.31KB, Downloaded 109 times)
Re: Eclipse crashes when attempting to load Lynda's exercise files [message #1739265 is a reply to message #1739249] Fri, 29 July 2016 07:28 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Kepler is 3 releases back; I thought Lynda was renowned for keeping current. The equivalent Neon package from http://www.eclipse.org/downloads/packages/eclipse-ide-java-developers/neonr should work similarly.
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Fri, 29 July 2016 07:29]
Report message to a moderator
Re: Eclipse crashes when attempting to load Lynda's exercise files [message #1739299 is a reply to message #1739265] Fri, 29 July 2016 13:31 Go to previous message
Nitin Dahyabhai wrote on Fri, 29 July 2016 07:28
Yeah..that's actually my fault, I've followed the first Google result for "Eclipse IDE for Java Developers", which points to Kepler. Smile
Anyways, seems it's not a version issue, I've now installed Neon (at a different directory) and the behavior remains the same..
Previous Topic:TestNG Plugin Troubles
Next Topic:javax.persistence.PersistenceException: No Persistence provider for EntityManager named XXXX
Current Time: Wed Feb 26 11:47:04 GMT 2020
Powered by FUDForum. Page generated in 0.07157 seconds
