Improve XMLResourceImpl's URI Fragments upon serialization [message #1739063] |
Wed, 27 July 2016 09:33 |
Michael Longo Messages: 8 Registered: July 2015 |
Junior Member |
For our internal needs, we upgraded our resource implementation to change how references are generated / read upon (de)serialization.
In our model, we have ids only on specific elements and not on the element contained into the said elements. But we also have a lot of references toward contained elements (and therefore without ids).
The "issue" we had was that the XMLResource generates references like:
"<resource>#<fragment uri>"
Where <fragment uri> is either <id> or <xpath-like>.
So we ended up with a lot of references looking like:
"<parent href="file.ext#//@elm1.0/@positions.1/@item.0/@description"/>"
Which is kind of lame because "//@elm1.0/@positions.1/@item.0" is an element with an id.
So, to make the long story short, we changed the generation to generate:
"<parent href="file.ext#<item id>/@description"/>"
Basically, it looks into the container of the element, looks for the closest id, and starts the xpath from the element prefixing by its id. (and if no element have an id, the full xpath is generated)
All this explanation just to ask you: do you think it is worth contributing our change to the XMLResourceImpl? (I mean to make a ticket, a pull request and so on)
Michael.
Re: Improve XMLResourceImpl's URI Fragments upon serialization [message #1739068 is a reply to message #1739063] |
Wed, 27 July 2016 10:17 |
Ed Merks Messages: 33140 Registered: July 2009 |
That sounds like https://bugs.eclipse.org/bugs/show_bug.cgi?id=494506 right?
On 27.07.2016 11:33, Michael Longo wrote:
> element with an id.
> Michael.
Ed Merks
Re: Improve XMLResourceImpl's URI Fragments upon serialization [message #1739069 is a reply to message #1739068] |
Wed, 27 July 2016 10:18 |
And it does sound useful. There are cases in Oomph where this would
help prevent errors when people textually merge the serialized setup
instances...
> right?
>> element with an id.
>> Thanks,
>> Michael.
Ed Merks
FUDForum. Page generated in 0.03085 seconds
