Home » Eclipse Projects » SWTBot » Headless Test with Maven/Tycho(Headless Test with Maven/Tycho)
Headless Test with Maven/Tycho [message #1738840] Mon, 25 July 2016 11:47 Go to next message
Vivek Veera is currently offline Vivek VeeraFriend
I am trying to run SWTBot tests on my RCP application in Headless mode. I have put below configuration in pom.xml of my Tests plugin. Are there any other configuration changes I need to make to get it working.
How can I verify on the command prompt if these tests are executed or not in headless mode. I don't see any tests related logs when I run maven build. Any help is appreciated.
<build>
<plugins>
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-surefire-plugin</artifactId>
<version>0.24.0</version>
<configuration>
<useUIHarness>true</useUIHarness>
<useUIThread>false</useUIThread>
<product>com.foo.bar.plugin.product</product>
<application>com.foo.bar.plugin.application</application>
</configuration>
</plugin>
</plugins>
</build>
Thanks.
Vivek
Re: Headless Test with Maven/Tycho [message #1738946 is a reply to message #1738840] Tue, 26 July 2016 09:19 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo BettiniFriend
On 25/07/2016 13:47, Vivek Veera wrote:
> <build>
> <plugins>
> <plugin>
> <configuration>
> </configuration>
> </plugin>
> </plugins>
> </build>
How do you run the maven build?
Something like mvn clean verify?
Are your test classes named something like XXXTest.java? Because that's
the default behavior of the surefire plugin: execute all the classes
that ends with "Test".
cheers
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Headless Test with Maven/Tycho [message #1739008 is a reply to message #1738946] Tue, 26 July 2016 18:28 Go to previous messageGo to next message
Thank you Lorenzo for the response.
Yes, all my Tests are named as XXXTest.java and placed them under src/test/java inside my Test plugin. I have mentioned packaging type for test plugin as 'eclipse-test-plugin'
I tried running build with 'mvn clean test' command initially but Tests are not run with this and build completes with SUCCESS.
I think Tycho surefire plugin executes tests in 'integration-test' phase therefore it does not pick SWTBot tests in 'test' phase. But I get below dependency error when I use 'mvn clean integration-test' or 'mvn clean verify' commands. I doubt if this is the correct command to use for executing my SWTBot tests using Tycho surefire plugin.
I need some help in getting the correct configuration and maven build commands for running my SWTBot tests using Tycho surefire plugin.
Here is the error it throws for my test plugin (com.foo.bar.tests)
[INFO] --- tycho-surefire-plugin:0.24.0:test (default-test) @ com.foo.bar.tests ---
[INFO] {osgi.ws=gtk, osgi.os=linux, osgi.arch=x86, org.eclipse.update.install.features=true}
[ERROR] Cannot resolve project dependencies:
[ERROR] You requested to install 'bundle org.eclipse.ui.ide.application 0.0.0' but it could not be found
[ERROR]
[ERROR] See http://wiki.eclipse.org/Tycho/Dependency_Resolution_Troubleshooting for help.
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
Thanks.
Vivek
[Updated on: Tue, 26 July 2016 18:30]
Report message to a moderator
Re: Headless Test with Maven/Tycho [message #1739267 is a reply to message #1739008] Fri, 29 July 2016 08:28 Go to previous messageGo to next message
comments inline
that's right: you need to run
mvn clean verify
well you need that in your target platform.
Are you using a target platform in your eclipse workspace?
cheers
Lorenzo
> [ERROR]
> [ERROR] See
> help.
> [INFO]
> [INFO]
Xtext Book:
Re: Headless Test with Maven/Tycho [message #1739448 is a reply to message #1739267] Mon, 01 August 2016 17:04 Go to previous message
Thanks Lorenzo. Yes, I am using target platform and this bundle (org.eclipse.ui.ide.application) is included in it.
Thanks.
Vivek
Previous Topic:Combination of Parameterized and SWTBotJunit4 runners
Next Topic:Timeout Issues in SWTBot Tests
Current Time: Wed May 12 15:33:06 GMT 2021
Powered by FUDForum. Page generated in 0.02047 seconds
