Home » Modeling » Papyrus » Framework-Independent Types
Re: Framework-Independent Types [message #1738377 is a reply to message #1738372] |
Tue, 19 July 2016 10:43   |
Ed Willink Messages: 6983 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">Hi<br>
<br>
The UMLforOCL profile enables you to define your own custom
DataTypes and characterize their numeric capabilities and OCL
behavior.<br>
<br>
<a class="moz-txt-link-freetext" href="http://">http://</a><cite class="_Rm"><a class="moz-txt-link-abbreviated" href="http://www.slideshare.net/EdWillink/the">www.slideshare.net/EdWillink/the</a>-<b>ocl</b>for<b>uml</b>-profile</cite><br>
<br>
Eclipse OCL tooling only uses the Integer/Real distinction at
present. In due course OCL evaluation / code generation may be
enforce limited precisions more accurately.<br>
<br>
Similarly other tools may begin to use the fuller specification.<br>
<br>
Regards<br>
<br>
Ed Willink<br>
<br>
<br>
On 19/07/2016 11:16, Philippe de Rochambeau wrote:<br>
</div>
<blockquote cite="mid:nmkul9$5c8$1@xxxxxxxxe.org" type="cite">Hi,
<br>
<br>
In Papyrus, you can select property types from the following
sources (there may be others I am not aware of):
<br>
- UML Types
<br>
- ECore Primitive Types
<br>
<br>
Because ECore contains the greater variety of data types (e.g.,
UML Types doesn't have a Date type,) I usually choose types from
there. Unfortunately, ECore is tied to the Eclipse Modeling
Framework, it isn't framework-independence.
<br>
<br>
How do you folks deal with this independence issue?
<br>
<br>
<br>
</blockquote>
<p><br>
</p>
<br /><br />
<hr style='border:none; color:#909090; background-color:#B0B0B0; height: 1px; width: 99%;' />
<table style='border-collapse:collapse;border:none;'>
<tr>
<td style='border:none;padding:0px 15px 0px 8px'>
<a href="https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient">
<img border=0 src="http://static.avast.com/emails/avast-mail-stamp.png" alt="Avast logo" />
</a>
</td>
<td>
<p style='color:#3d4d5a; font-family:"Calibri","Verdana","Arial","Helvetica"; font-size:12pt;'>
This email has been checked for viruses by Avast antivirus software.
<br><a href="https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient">www.avast.com</a>
</p>
</td>
</tr>
</table>
<br />
</body>
</html>
Re: Framework-Independent Types [message #1738399 is a reply to message #1738397] |
Tue, 19 July 2016 12:58   |
Another option could be to define your primitive types as part of, or in a separate, imported, UML model. Note that this uses standard UML capabilities. In addition, as part of Papyrus, these can be built and distributed as (model) libraries, making it easier to share in a team. Placing it in a library has the added advantage of write protection. This is, for example, what we have done in Papyrus-RT to easily expose the UML-RT primitives, which are not found in any other library, the the Papyrus-RT users.
As you have not defined what you meant by "platform indepdendence", I am unsure if that addresses your need , but I wanted to mention that alternative.
/Charles Rivet
Re: Framework-Independent Types [message #1738410 is a reply to message #1738399] |
Tue, 19 July 2016 13:35   |
Hi Charles
Libraries may be a good way to 'implement' them but you still need to
use the UMLforOCL profile to 'specify' them so that OCL knows that
expressions involving variables typed by your PrimitiveTypes names may
use Integer / Real operations. (Unless your PrimitiveTypes totally
displace OCL types and you provide explicit toInteger() etc conversion
methods.)
Ed Willink
> alternative.
https://www.avast.com/antivirus
Re: Framework-Independent Types [message #1738419 is a reply to message #1738410] |
Tue, 19 July 2016 15:43  |
[quote title=Ed Willink wrote on Tue, 19 July 2016 09:35]Hi Charles
methods.)
Ed Willink
Hi Ed,
I agree in principle. in the particular case of their use in Papyrus-RT, this is not necessary because, as part of the principles of operation of the tool, these are only used by our code generator, which explicitly understands their meaning. Those properties are not (at least yet, depending on users explicit needs) used in operations in the model.
Thanks for the feedback!
Charles
[...snip...]
/Charles Rivet
Current Time: Sat Jan 16 01:06:16 GMT 2021
Powered by FUDForum. Page generated in 0.02259 seconds
