Classify exit code after test execution [message #1737903] |
Thu, 14 July 2016 02:40 |
Dan Huang Messages: 10 Registered: June 2016 |
For now, after execute testexec.exe the exit code only classify 1 and 0. But there are 4 error in event handler (ex: Check failed, Action error, Component not found, Configuration error).
I wondering is it possible to classify those error, that will be easier handle self's bat job after Jubula testing phase.
[Updated on: Thu, 14 July 2016 02:41] Report message to a moderator
Re: Classify exit code after test execution [message #1737917 is a reply to message #1737903] |
Thu, 14 July 2016 07:23 |
Hi Dan,
there currently is no way to determine the error directly. You can however use the -resultdir and -resultname parameters, as described in our manual, to create HTML and XML result files in the specified folder. You could then use these files to determine and handle the errors that occured during test execution.
Kevin
[Updated on: Thu, 14 July 2016 07:24] by Moderator Report message to a moderator
FUDForum. Page generated in 0.03485 seconds
