Home » Eclipse Projects » EGit / JGit » Listing tags in egit gets out of memory error(When listing tags while trying to compare to tag I get an out of memory error)
Listing tags in egit gets out of memory error [message #1737895] Wed, 13 July 2016 21:12 Go to next message
David Marshall is currently offline David MarshallFriend
I have a repo that was converted from CVS that has 17000+ tags and millions of individual commits. When I right click on a java class and choose Compare With --> Branch, Tag, or Reference it brings up a window where there are Local, References, Remote Tracking and tags groups. When I try to expand the tag group to list all the tags it takes an out of memory error.
In order to try to figure out what was happening I wrote a java program using JGit. I found that I could list the tags just fine, but if I tried to load the commits for the tags it took the error. I found something that seemed to say that was what egit is doing.
Has anyone else ran into this issue? Is there a configuration in eclipse to prevent the listing of tags from loading the commits until after you choose which tag you want to actually compare?
Re: Listing tags in egit gets out of memory error [message #1738063 is a reply to message #1737895] Fri, 15 July 2016 13:33 Go to previous message
Andrey Loskutov is currently offline Andrey LoskutovFriend
Member
David Marshall wrote on Wed, 13 July 2016 23:12
Nope, there are no config options... Please file a bug.
Previous Topic:(solved) Newbie getting bizarre ClassNotFoundException: JSchException
Next Topic:Rebase Submodule
Current Time: Sun Feb 16 19:01:12 GMT 2020
Powered by FUDForum. Page generated in 0.01966 seconds
