Home » Eclipse Projects » WindowBuilder » I have a problem installing Java WindowBuilder(I have a problem installing Java WindowBuilder)
I have a problem installing Java WindowBuilder [message #1737870] Wed, 13 July 2016 16:07 Go to next message
Igor St is currently offline Igor StFriend
im a new user of Eclipse (basically im a nube), i have Eclipse Neon and
i found a tutorial on YouTube on how to install gui and the guy shows to go
Help>Install new Software...> (in the "Work with:", to select the version(release) of Eclipse)>General Purpose Tools> Swing Designer,Swing...>
and then install it.
But when i go to "General Purpose Tools" i dont have anything Swing or WindowBuilder.
Also if i uncheck the box of "Hide items that are already installed" it still doesnt show up.
So if someone could help me.
Thank you Smile
Re: I have a problem installing Java WindowBuilder [message #1738315 is a reply to message #1737870] Tue, 19 July 2016 01:36 Go to previous messageGo to next message
Chris Violetti is currently offline Chris ViolettiFriend
WindowBuilder is not supported in the current version of Eclipse. It's coming September 22nd.
https://projects.eclipse.org/projects/tools.windowbuilder
Re: I have a problem installing Java WindowBuilder [message #1738755 is a reply to message #1738315] Sat, 23 July 2016 03:00 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
The new WB update site for Neon can be found here:
http://download.eclipse.org/windowbuilder/WB/integration/4.6/
Thank you Lars, Frederic, and Patrik!!
Re: I have a problem installing Java WindowBuilder [message #1738794 is a reply to message #1738755] Sun, 24 July 2016 18:13 Go to previous message
Thank you i just tried it and it works Very Happy
Previous Topic:Can't find SWT Designer on Eclipse Neon
Next Topic:WindowBuilder DesignerException 1100
Current Time: Mon Jan 20 17:07:20 GMT 2020
Powered by FUDForum. Page generated in 0.01596 seconds
