Home » Newcomers » Newcomers » Eclipse Error on start - "Failed to find main class in C:\Users\.../org.eclipse.equinox.launche
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.ecl [message #1737657 is a reply to message #1737646] |
Mon, 11 July 2016 15:39 |
Ed Merks Messages: 33137 Registered: July 2009 |
Riley,
Comments below.
On 11.07.2016 16:40, Riley Groeschel wrote:
> I installed a few games, and AMD installed their Dual-Core Optimizer,
> but nothing Java related.
It was more a question, did you install things into your Eclipse IDE.
> The path does not exist, a similarly named file one version newer
> exists in that folder.
What exactly is the name of the file in the plugins folder of the
installation? In my Neon installations it's exactly
org.eclipse.equinox.launcher_1.3.200.v20160318-1642 as you show below.
And this is the newest released version of this plugin...
In any case, the name of the launcher jar actually in the installation's
plugins folder must match exactly the -start argument.
When it worked they must have been the same. It should (could) only
change as a result of installing something in the IDE.
> My eclipse.ini looks like this:
> -startup
> plugins/org.eclipse.equinox.launcher_1.3.200.v20160318-1642.jar
> --launcher.library
> C:\Users\oreo4\.p2\pool\plugins\org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.400.v20160518-1444
> -product
> org.eclipse.epp.package.java.product
> --launcher.defaultAction
> openFile
> -showsplash
> org.eclipse.platform
> --launcher.appendVmargs
> -vmargs
> -Dosgi.requiredJavaVersion=1.8
> -XX:+UseG1GC
> -XX:+UseStringDeduplication
> -Xms256m
> -Xmx1024m
> -Declipse.p2.max.threads=10
> -Doomph.update.url=http://download.eclipse.org/oomph/updates/milestone/latest
> -Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/
> Ed Merks wrote on Mon, 11 July 2016 06:11
>> Did you install something extra during that day? What does your
>> eclipse.ini look like? You said the file at that path exists. Is it
>> non-empty? It's a jar, so can you unzip it to look at the contents?
>> On 11.07.2016 00:49, Riley Groeschel wrote:
>> > Turns out, after another day, it's giving me the same exact error.
Ed Merks
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org.ecl [message #1737663 is a reply to message #1737657] |
Mon, 11 July 2016 16:42 |
Riley Groeschel Messages: 8 Registered: July 2016 |
I don't understand what you mean by "Comments below".
EDIT: Never mind, realized you wrote in the middle of my post. The name of the file in the plugins folder was org.eclipse.equinox.launcher_1.3.201.v20160318-1642.jar, but now it is the normal one. Still getting the error.
Ed Merks wrote on Mon, 11 July 2016 15:39Riley,
Comments below.
> -startup
> --launcher.library
> -product
> openFile
> -showsplash
> -vmargs
> -XX:+UseG1GC
> -Xms256m
> -Xmx1024m
[Updated on: Mon, 11 July 2016 16:52] Report message to a moderator
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org [message #1737665 is a reply to message #1737663] |
Mon, 11 July 2016 16:48 |
That mean my comments inline mixed between your comments.
To repeat them...
>> Riley,
>> Comments below.
>> Optimizer, > but nothing Java related. It was more a question, did
>> > The path does not exist, a similarly named file one version newer >
>> below. And this is the newest released version of this plugin...
>> installation's plugins folder must match exactly the -start argument.
>> > -startup
>> > --launcher.library
>> > -product
>> > openFile
>> > -showsplash
>> > -vmargs
>> > -XX:+UseG1GC
>> > -Xms256m
>> > -Xmx1024m
>> it >> non-empty? It's a jar, so can you unzip it to look at the
>> contents?
Ed Merks
Re: Eclipse Error on start - "Failed to find main class in C:\Users\.../org [message #1737858 is a reply to message #1737665] |
Wed, 13 July 2016 14:31 |
I've tried installing it again and figured out that it only works on the first run after installation.
Ed Merks wrote on Mon, 11 July 2016 16:48That mean my comments inline mixed between your comments.
To repeat them...
>> Riley,
>> Comments below.
>> > -startup
>> > --launcher.library
>> > -product
>> > openFile
>> > -showsplash
>> > -vmargs
>> > -XX:+UseG1GC
>> > -Xms256m
>> > -Xmx1024m
>> contents?
Current Time: Sat Apr 20 01:47:57 GMT 2024
Powered by FUDForum. Page generated in 0.09001 seconds
