Re: [CDO] NPE in AbstractHorizintalClassMapping.initTable() [message #1737470 is a reply to message #1737467] |
Fri, 08 July 2016 13:37 |
Am 08.07.2016 um 16:02 schrieb David Wynter:
> I am using CDO 4.4.1.v20160215 in Kepler
Kepler is very old, but probably unrelated to CDO issues.
CDO 4.4 is also out of maintenance. Have you tried the same scenario with the just release CDO 4.5?
What database are you using?
> Here is my stack trace, which occurs when I try to save the model
> !STACK 0
> org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: java.lang.NullPointerException
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.initTable(AbstractHorizontalClassMapping.java:127)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.<init>(AbstractHorizontalClassMapping.java:111)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditClassMapping.<init>(HorizontalAuditClassMapping.java:94)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalAuditMappingStrategy.doCreateClassMapping(HorizontalAuditMappingStrategy.java:48)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.createClassMapping(AbstractMappingStrategy.java:678)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getClassMapping(AbstractMappingStrategy.java:726)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.queryXRefs(AbstractHorizontalMappingStrategy.java:164)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.queryXRefs(HorizontalMappingStrategy.java:189)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.queryXRefs(DBStoreAccessor.java:337)
> at
> org.eclipse.emf.cdo.internal.server.TransactionCommitContext$XRefContext.getXRefs(TransactionCommitContext.java:1601)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.checkXRefs(TransactionCommitContext.java:1267)
You could try the same usage scenario without referential integrity checks. That could gives us some pointers.
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:647)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:48)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
> at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
> at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:1144)
> at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:1137)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:293)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:101)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:110)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:98)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:100)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:369)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:73)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
> at java.lang.Thread.run(Thread.java:745)
> at
> org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:89)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commitSynced(CDOTransactionImpl.java:1316)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1290)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1257)
> at com.yambina.edm.commons.platform.internalservices.EResourceService.commit(EResourceService.java:339)
> at com.yambina.edm.commons.platform.EDMPlatform$3.run(EDMPlatform.java:293)
> I used the CDO Explorer view to open the model and when I try to save it I get the same exception.
> The tablename it is trying to init is the EAnnotation table (line 118 of AbstractHorizontalClassMapping) There is no
> schemaTransaction set for IDBDatabase.
I'd need exact steps to follow in order to reproduce the problem ;-(
> Some guidance on how to debug this would be welcome.
It would probably be good to set a breakpoint on the line that acquires the null pointer and then step through the code.
Depending on what you find out I might be able to give more advice.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
FUDForum. Page generated in 0.02962 seconds
