Home » Eclipse Projects » Hudson » Steps to migrate from v2.2.1 to 3.3.2 ?
Steps to migrate from v2.2.1 to 3.3.2 ? [message #1737387] Thu, 07 July 2016 16:56 Go to next message
Z W is currently offline Z WFriend
Hi All
Are there steps we can use to follow/migrate from v2.2.1 to 3.3.2 while preserving all the users and jobs configured in v2.2.1 into v3.3.2 ?
This install instructions on the Hudson page isn't adequate.
Re: Steps to migrate from v2.2.1 to 3.3.2 ? [message #1737412 is a reply to message #1737387] Thu, 07 July 2016 21:18 Go to previous messageGo to next message
Bob Foster is currently offline Bob FosterFriend
Member
It's probably wise to wait until Winston gets back from vacation for a full answer. A few points:
- Back up your entire Hudson home before attempting to upgrade, and work from a copy.
- Run in Java 7.
- You'll need to upgrade all the plugins you're using to the latest versions, which you can see at http://hudson-ci.org/PluginCentral/site/3.3.2/
If you're using a plugin that isn't in the current list, it probably won't work in Hudson 3.
- Be sure to install all recommended plugins.
By all means, ask questions.
Bob
Re: Steps to migrate from v2.2.1 to 3.3.2 ? [message #1737667 is a reply to message #1737412] Mon, 11 July 2016 17:44 Go to previous message
Winston Prakash is currently offline Winston PrakashFriend
Bob's recommendation sounds good. One additional step would be to disable the security if you are using security provided through plugin and re-enable it after starting Hudson using 3.3.2
Winston Prakash
Eclipse Hudson team
Previous Topic:When multi modules maven project merge, all modules' Hudson jobs were starting
Next Topic:Git url of repository with parameter
Current Time: Sat Oct 31 20:31:55 GMT 2020
Powered by FUDForum. Page generated in 0.01436 seconds
