Home » Eclipse Projects » Rich Client Platform (RCP) » Tooltip not getting set for Command having new Wizard(Tooltip not getting set for Command having new Wizard - org.eclipse.ui.newWizard)
Tooltip not getting set for Command having new Wizard [message #1737354] Thu, 07 July 2016 10:11 Go to next message
I am adding command button using plugin.xml --> Extensions in
Menu --> Toolbar.
Tooltip not getting set for Command having new Wizard - org.eclipse.ui.newWizard.
I tried to set tooltip value pro-grammatically in class extending WorkbenchWindowAdvisor, method postWindowOpen() but it is not getting reflected.
Re: Tooltip not getting set for Command having new Wizard [message #1740595 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Please let me know if I should consider it as a limitation?
Re: Tooltip not getting set for Command having new Wizard [message #1742335 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742350 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742373 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742389 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742404 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742426 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742439 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1742452 is a reply to message #1737354] Tue, 16 August 2016 01:53 Go to previous messageGo to next message
Re: Tooltip not getting set for Command having new Wizard [message #1816051 is a reply to message #1740595] Fri, 18 October 2019 03:37 Go to previous message
I have also encountered this problem recently while working on https://www.eclipse.org/forums/index.php/m/1816027/#msg_1816027
Is this a known problem? Should I file a Bugzilla entry for that?
Previous Topic:Minimal stand-alone help system does not show my help plugin
Next Topic:Error on exporting product
Current Time: Tue Mar 25 03:01:30 EDT 2025
Powered by FUDForum. Page generated in 0.04261 seconds
