Home » Eclipse Projects » e(fx)clipse » Neon and 2.4.0 site target linux 64 bit problem
Neon and 2.4.0 site target linux 64 bit problem [message #1737118] Tue, 05 July 2016 20:52 Go to next message
John Bodkin is currently offline John BodkinFriend
Member
I was working with e(fx)clipse 2.3.0 and Mars 4.5.2 with no issues. I moved to 2.4.0 and 4.6.0 today. I mirrored the targets. The runnable target works fine but when I run the Maven-Tycho build (which depends on the p2 site target) it states:
Missing requirement: toolingorg.eclipse.equinox.launcher.gtk.linux.x86_64 1.1.400.v20160518-1444 requires 'bundle org.eclipse.equinox.launcher.gtk.linux.x86_64 1.1.400.v20160518-1444' but it could not be found
Notice the blank space between x86_64 and 1.1.400. The jar for this platform executable is present except it has an underscore where the blank space currently is. I tried renaming the bundle so it has the space but the same error message is produced. I renamed it again to its original name.
I took linux gtk x86_64 out of the build and left the linux gtk x86 and the win32 win32 x86_64 environments in the build. The build completes successfully and the zip files have executables that launch.
I also tried this using the remote site (instead of a local mirror) but I get :
Missing requirement: toolingwin32.win32.x86_64org.eclipse.core.runtime 1.0.0 requires 'bundle org.eclipse.core.runtime 3.12.0.v20160606-1342' but it could not be found
Here is my config pom:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
	<modelVersion>4.0.0</modelVersion>
	<groupId>my.group.id</groupId>
	<artifactId>my.group.id.artifact.id</artifactId>
	<version>1.0.0-SNAPSHOT</version>
	<packaging>pom</packaging>
	<properties>
		<tycho.version>0.25.0</tycho.version>
		<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<!-- 		<efxclipse.target>file:/${git.repo}/TEX/build-site-target/efxclipse-2.4.0/</efxclipse.target> -->
<!-- 		<eclipse.target>file:/${git.repo}/TEX/build-site-target/eclipse-4.6.0/</eclipse.target> -->
		<efxclipse.target>http://download.eclipse.org/efxclipse/runtime-released/2.4.0/site/</efxclipse.target>
		<eclipse.target>http://download.eclipse.org/releases/neon</eclipse.target>
	</properties>
	<repositories>
		<repository>
			<id>eclipse 4.6.0</id>
			<url>${eclipse.target}</url>
			<layout>p2</layout>
		</repository>
		<repository>
			<id>e(fx)clipse 2.4.0</id>
			<url>${efxclipse.target}</url>
			<layout>p2</layout>
		</repository>
	</repositories>
	<build>
		<plugins>
			<plugin>
				<groupId>org.eclipse.tycho</groupId>
				<artifactId>tycho-maven-plugin</artifactId>
				<version>${tycho.version}</version>
				<extensions>true</extensions>
			</plugin>
			<plugin>
				<artifactId>target-platform-configuration</artifactId>
				<configuration>
					<environments>
<!-- 						<environment> -->
<!-- 							<os>linux</os> -->
<!-- 							<ws>gtk</ws> -->
<!-- 							<arch>x86</arch> -->
<!-- 						</environment> -->
						<environment>
							<os>linux</os>
							<ws>gtk</ws>
							<arch>x86_64</arch>
						</environment>
<!-- 							<os>win32</os> -->
<!-- 							<ws>win32</ws> -->
<!-- 							<arch>x86_64</arch> -->
					</environments>
				</configuration>
			</plugin>
		</plugins>
	</build>
</project>
This is my script to mirror the repo. This worked just fine for the 4.5.2 and 2.3.0 targets:
<project name="Mirror" default="mirrorRepos">
	<!-- The P2 repository location to mirror -->
	<property name="efxclipseRepository" value="http://download.eclipse.org/efxclipse/runtime-released/2.4.0/site" />
	<property name="eclipseRepository" value="http://download.eclipse.org/releases/neon" />
	<!-- The location to place the mirrored repository (root location) -->
	<property name="baseP2RepoHome" value="C:/TEMP/target" />
	<property name="baseEclipseP2RepoHome" value="${baseP2RepoHome}" />
	<!-- Defines each p2 destination with a version identifier. -->
	<property name="eclipseReleaseNameVer" value="eclipse-4.6.0" />
	<property name="efxclipseReleaseNameVer" value="efxclipse-2.4.0" />
	<target name="mirrorRepos" description="Builds the entire p2 mirror set.">
		<antcall target="createMirror" />
	</target>
	<target name="createMirror" description="Mirrors the Eclipse 4.6.0 launcher feature and efxclispe 2.4.0 repository items. Turns them into runnables">
		<p2.mirror source="${eclipseRepository}" verbose="true" log="C:/TEMP/p2NeonMirror.log" validate="true" destination="file://${baseEclipseP2RepoHome}/site/${eclipseReleaseNameVer}" >
			<iu id="org.eclipse.equinox.executable.feature.group" />
		</p2.mirror>
		<p2.mirror source="${efxclipseRepository}" verbose="true" log="C:/TEMP/p2FXMirror.log" validate="true" destination="file://${baseEclipseP2RepoHome}/site/${efxclipseReleaseNameVer}" >
 			<iu id="org.eclipse.fx.target.feature.feature.group" />
		</p2.mirror>
		<p2.repo2runnable>
		  <repository location="file://${baseEclipseP2RepoHome}/runnable/${eclipseReleaseNameVer}" />
		  <source>
		    <repository location="file://${baseEclipseP2RepoHome}/site/${eclipseReleaseNameVer}" />
		  </source>
		</p2.repo2runnable>
		<p2.repo2runnable>
		  <repository location="file://${baseEclipseP2RepoHome}/runnable/${efxclipseReleaseNameVer}" />
		  <source>
		    <repository location="file://${baseEclipseP2RepoHome}/site/${efxclipseReleaseNameVer}" />
		  </source>
		</p2.repo2runnable>
	</target>
</project>
Thanks for any help you can provide.
[Updated on: Wed, 06 July 2016 17:32]
Report message to a moderator
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737157 is a reply to message #1737118] Wed, 06 July 2016 07:44 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Hi John,
Can you file a bug for that. I'll try to track that down. Is your
application a pure e4 and JavaFX app or a SWT-JavaFX mixed one?
Tom
> original name.
> I get :
> <properties>
> </properties>
> <repositories>
> <repository>
> <layout>p2</layout>
> </repository>
> <repository>
> <layout>p2</layout>
> </repository>
> </repositories>
> <build>
> <plugins>
> <plugin>
> </plugin>
> <plugin>
> <configuration>
> <environments>
> <environment>
> <os>linux</os>
> <ws>gtk</ws>
> <arch>x86_64</arch>
> </environment>
> </environments>
> </configuration>
> </plugin>
> </plugins>
> </build>
> </project>
> set.">
> </target>
> runnables">
> </p2.mirror>
> </p2.mirror>
> <p2.repo2runnable>
> <repository
> <source>
> <repository
> </source>
> </p2.repo2runnable>
> <p2.repo2runnable>
> <repository
> <source>
> <repository
> </source>
> </p2.repo2runnable>
> </target>
> </project>
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737161 is a reply to message #1737157] Wed, 06 July 2016 07:51 Go to previous messageGo to next message
BTW for the lookup the jar name is not relevant but the information in
the artifacts.jar/contents.jar.
Since 2.4.0 we also bundle the native-launcher into our target maybe
there's a mismatch now?
Tom
On 06.07.16 09:44, Tom Schindl wrote:
> Hi John,
> Tom
>> original name.
>> I get :
>> <?xml version="1.0" encoding="UTF-8"?>
>> <properties>
>> </properties>
>> <repositories>
>> <repository>
>> <layout>p2</layout>
>> </repository>
>> <repository>
>> <layout>p2</layout>
>> </repository>
>> </repositories>
>> <build>
>> <plugins>
>> <plugin>
>> </plugin>
>> <plugin>
>> <configuration>
>> <environments>
>> <environment>
>> <os>linux</os>
>> <ws>gtk</ws>
>> <arch>x86_64</arch>
>> </environment>
>> </environments>
>> </configuration>
>> </plugin>
>> </plugins>
>> </build>
>> </project>
>> set.">
>> </target>
>> runnables">
>> </p2.mirror>
>> </p2.mirror>
>> <p2.repo2runnable>
>> <repository
>> <source>
>> <repository
>> </source>
>> </p2.repo2runnable>
>> <p2.repo2runnable>
>> <repository
>> <source>
>> <repository
>> </source>
>> </p2.repo2runnable>
>> </target>
>> </project>
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737227 is a reply to message #1737157] Wed, 06 July 2016 13:29 Go to previous messageGo to next message
Member
it is pure e4 and JavaFX app
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737231 is a reply to message #1737227] Wed, 06 July 2016 13:49 Go to previous messageGo to next message
So why do you reference the 4.6.0 repo? Can you remove that one?
Tom
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737232 is a reply to message #1737161] Wed, 06 July 2016 13:54 Go to previous messageGo to next message
Member
I removed the <eclipse.target> from the config pom and it compiled successfully through Maven-Tycho. Produced a zip and a working executable for all platforms.
I doubt it matters but the neon versions on the executables is 1.1.400 and the executables in 2.4.0 are 1.1.300.
Thanks again for the assist.
Re: Neon and 2.4.0 site target linux 64 bit problem [message #1737237 is a reply to message #1737232] Wed, 06 July 2016 14:01 Go to previous message
Well yes our target platform in the 2.4.0 release still contains Mars.1
(Mars.2 has had a regression) and we did not had time to upgrade our
target to neon for the 2.4.0 release.
The nightly builds for 3.0.0 just today was modified to use Neon.1.
Tom
Previous Topic:e(fx)clipse for Java 9
Next Topic:@Preference - check if value exists
Current Time: Wed Feb 24 21:24:07 GMT 2021
Powered by FUDForum. Page generated in 0.02490 seconds
