Home » Modeling » TMF (Xtext) » Xtext & Sirius Integrate Problems
icon9.gif  Xtext & Sirius Integrate Problems [message #1737044] Tue, 05 July 2016 09:27 Go to next message
Nicholas Kong is currently offline Nicholas KongFriend
Member
I am fresh man in Xtext.
Now I am try to use the Sirius Sample to integrate with Xtext, But I find some problems:
Here is the meta-model diagram:
index.php/fa/26386/0/
1: After I import the existing meta-model,the Xtext grammar give a warnning like this:
"The feature 'children' is a bidirectional reference. "
And I can't create a model in instance Eclipse using this meta model.The error like this:
index.php/fa/26384/0/
Is it means that Xtext not support bi-directional reference(EOpposite)? If I want to use this feature, How should I do.
2: When I run a instance Eclipse, and want to use this meta-model to create model with Sirius, there is a problem when the model is created. It seems like the wizard dose not create Family ***{ } grammar. So I cant save the instance model.
index.php/fa/26385/0/
Are there any one who knows if I want use Xtext & Sirius integrate, Where I should be noted?
Thank you!
[Updated on: Wed, 06 July 2016 03:05]
Report message to a moderator
Re: Xtext & Sirius Integrate Problems [message #1737087 is a reply to message #1737044] Tue, 05 July 2016 15:11 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
yes bidi refs are not supported well.
in your grammar / the inferred grammar you have only one direction now?
if yes mark the other direction as transient via org.eclipse.xtext.serializer.sequencer.ITransientValueService
Twitter : @chrdietrich
Re: Xtext & Sirius Integrate Problems [message #1737131 is a reply to message #1737087] Wed, 06 July 2016 03:18 Go to previous messageGo to next message
Member
Christian Dietrich wrote on Tue, 05 July 2016 15:11
Thanks for your answer, Christain.
The edge "/father" & "/mother" is set the 'Derived' property in Ecore.
But this reference is not appearance in Xtext, the grammar as this:
// automatically generated by Xtext
grammar org.eclipse.sirius.sample.basicfamily.Dsl with org.eclipse.xtext.common.Terminals
import "platform:/resource/org.eclipse.sirius.sample.basicfamily/model/basicfamily.ecore"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Family returns Family:
	{Family}
	'Family'
	name=ID
		('members' '{' members+=Person ( "," members+=Person)* '}' )?
Person returns Person:
	Man | Woman;
Man returns Man:
	{Man}
	'Man'
	name=ID
		('children' '(' children+=[Person|STRING] ( "," children+=[Person|STRING])* ')' )?
		('parents' '(' parents+=[Person|STRING] ( "," parents+=[Person|STRING])* ')' )?
Woman returns Woman:
	{Woman}
	'Woman'
	name=ID
As you said "mark the other direction as transient via org.eclipse.xtext.serializer.sequencer.ITransientValueService", what should I do for this.
Would you please give me more detail introduction?
Note:
I have attached the source code.
Thanks a lot.
[Updated on: Wed, 06 July 2016 03:25]
Re: Xtext & Sirius Integrate Problems [message #1737136 is a reply to message #1737131] Wed, 06 July 2016 04:44 Go to previous messageGo to next message
i am not sure what you need as details
@SuppressWarnings("restriction")
public class MyTransientValueService extends LegacyTransientValueService {
	public ValueTransient isValueTransient(EObject semanticObject, EStructuralFeature feature) {
		if (feature == YourDslPackage.Literals.ABC_XYZ) {
			return ValueTransient.YES;
		return super.isValueTransient(semanticObject, feature);
def Class<? extends ITransientValueService> bindITransientValueService2() {
Re: Xtext & Sirius Integrate Problems [message #1737362 is a reply to message #1737136] Thu, 07 July 2016 14:58 Go to previous message
Member
Christian Dietrich wrote on Wed, 06 July 2016 04:44
I will try it! Thanks a lot!
Previous Topic:Problem with importing several projects
Next Topic:Xtext Project From Existing Ecore Models Problems
Current Time: Tue Apr 16 10:58:56 GMT 2024
Powered by FUDForum. Page generated in 0.84407 seconds
