Home » Modeling » GMF (Graphical Modeling Framework) » LayoutManager add unwanted Border Lines between nested Rectangles
LayoutManager add unwanted Border Lines between nested Rectangles [message #1736745] Fri, 01 July 2016 12:41
Niklas Klipphahn is currently offline Niklas KlipphahnFriend
Hey,
I've got a problem with LayoutManagers adding unwanted Border Lines between nested Rectangles.
Basically I defined a FigureDescriptor like this:
FigureDescriptor x
---Rectangle OuterRectangle
------LayoutManager Y
------Rectangle UpperRectangle
-------------LayoutManagerData Z1
------Rectangle CentralRectangle
-------------LayoutManagerData Z2
------Rectangle Lowerrectangle
-------------LayoutManagerData Z3
I've set Outline to false for UpperRectangle, CentralRectangle and LowerRectangle. Each of them is mapped as a Compartment.
Outline is false for OuterRectangle as well. I've tried aligning the nested Rectangles with XY Layout and BorderLayout. But everytime I get Border lines between the nested Rectangles as you can see on the screenshot.index.php/fa/26321/0/
(btw. the outline at the bottom and left is wanted, and there's no border line at the upper left, because there's a label)
Is it possible to remove those border lines? (possibly via changing code)
Thanks in advance.
Previous Topic:How to Generate notation model for a domain model
Next Topic:How to get all Editparts from a Sirius Diagram
Current Time: Wed Feb 24 21:06:29 GMT 2021
Powered by FUDForum. Page generated in 0.02263 seconds
