Home » Eclipse Projects » OM2M » Running mn-cse in virtual machine.
Running mn-cse in virtual machine. [message #1736633] Thu, 30 June 2016 16:41 Go to next message
Trung Luu is currently offline Trung LuuFriend
Member
Hi all, i'm trying to run the IN-CSE in my computer running Windows and the MN-CSE in a Virtual Machine running Linux OS. I configured the CseBase IP and CseRemote IP according to the IP of the computer and the VM. However, the MN-CSE cannot register in the IN-CSE. I ask if anyone used to do this task for help. Thank you.
Re: Running mn-cse in virtual machine. [message #1736701 is a reply to message #1736633] Fri, 01 July 2016 09:06 Go to previous messageGo to next message
Guillaume Garzone is currently offline Guillaume GarzoneFriend
Member
Hello Trung Luu,
The IN must be able to reach the ip:port of the MN and the MN must be able to reach the ip:port of your IN.
Could you check if you can ping (or whatever) each node from the VM and the Windows side?
Guillaume
Re: Running mn-cse in virtual machine. [message #1736781 is a reply to message #1736701] Fri, 01 July 2016 16:31 Go to previous messageGo to next message
Member
I tried to run IN-CSE and MN-CSE in different Virtual Machine and it work. But between real PC and VM, it can ping the IP of the another but the request is still not sent. I don't know what the problem is. Thanks for your help.
Re: Running mn-cse in virtual machine. [message #1736940 is a reply to message #1736781] Mon, 04 July 2016 13:30 Go to previous messageGo to next message
Member
Can you try to run both IN and MN on your real PC to be sure that there is not a hidden issue there?
Guillaume
Re: Running mn-cse in virtual machine. [message #1737214 is a reply to message #1736940] Wed, 06 July 2016 12:55 Go to previous messageGo to next message
Mahdi Ben Alaya is currently offline Mahdi Ben AlayaFriend
Trung, please tell us if Guillaume remark helped you to solve your issue otherwise give us more details.
Re: Running mn-cse in virtual machine. [message #1737222 is a reply to message #1737214] Wed, 06 July 2016 13:08 Go to previous messageGo to next message
Member
I ran both IN and MN in my PC and it works perfectly, it happen so when I run both on Virtual Machine Linux Debian. But when I run 1 of them in my real PC and 1 in Virtual Machine, the request from MN cannot be sent to IN. I'm sorry for late reply.
Best Regards,
Re: Running mn-cse in virtual machine. [message #1737250 is a reply to message #1737222] Wed, 06 July 2016 15:43 Go to previous messageGo to next message
I think you need to open required ports on your machines. E.g. 8080 to reach the IN.
Re: Running mn-cse in virtual machine. [message #1737251 is a reply to message #1737250] Wed, 06 July 2016 15:44 Go to previous messageGo to next message
Member
Dear Mahdi,
it works now, thanks for fast support.
Best Regards,
Trung
Re: Running mn-cse in virtual machine. [message #1737253 is a reply to message #1737251] Wed, 06 July 2016 15:46 Go to previous message
Happy it is working for you.
I will try to help you on the other issue.
Mahdi
[Updated on: Wed, 06 July 2016 15:48]
Report message to a moderator
Previous Topic:Create your own Plugin
Next Topic:Trouble with dependencies
Current Time: Sat Jul 11 15:45:48 GMT 2020
Powered by FUDForum. Page generated in 0.02513 seconds
