Home » Eclipse Projects » BIRT » Runtime exception occures when write any code into onPageStart or onPageEnd evetns
Runtime exception occures when write any code into onPageStart or onPageEnd evetns [message #1736532] Thu, 30 June 2016 08:52 Go to next message
Viktor Kalman is currently offline Viktor KalmanFriend
Hi!
When I try to write any code (even if only a comment) into onPageStart or onPageEnd event then always runtime exception is the result.
Is it a bug?
I need to create reports that restart page numbers at every groups.
Please any help!
Thanks.
Viktor
Eclipse Mars - BIRT 4.5.0
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
AxisFault
 faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
 faultSubcode:
 faultString: org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
 faultActor:
 faultNode:
 faultDetail:
    {http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.report.service.api.ReportServiceException: Error happened while running the report.
    at org.eclipse.birt.report.service.ReportEngineService.throwDummyException(ReportEngineService.java:1115)
    at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:943)
    at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
    at org.eclipse.birt.report.service.actionhandler.BirtRunAndRenderActionHandler.__execute(BirtRunAndRenderActionHandler.java:76)
    at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
    at org.eclipse.birt.report.presentation.aggregation.layout.EngineFragment.doService(EngineFragment.java:318)
    at org.eclipse.birt.report.presentation.aggregation.AbstractBaseFragment.service(AbstractBaseFragment.java:76)
    at org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(BirtEngineServlet.java:116)
    at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGet(BaseReportEngineServlet.java:185)
    at org.eclipse.birt.report.servlet.BaseReportEngineServlet.doPost(BaseReportEngineServlet.java:224)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
    at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
    at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
    at org.eclipse.birt.report.servlet.BaseReportEngineServlet.service(BaseReportEngineServlet.java:116)
    at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
    at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1271)
    at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:162)
    at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:63)
    at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl.doDispatch(HttpServiceRuntimeImpl.java:413)
    at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl.doDispatch(HttpServiceRuntimeImpl.java:341)
    at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl.doDispatch(HttpServiceRuntimeImpl.java:204)
    at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.processAlias(ProxyServlet.java:91)
    at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:70)
    at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:356)
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:587)
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221)
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
    at org.eclipse.jetty.server.Server.handle(Server.java:497)
    at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
    at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
    at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
    at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
    at org.eclipse.birt.report.engine.api.impl.EngineTask.handleFatalExceptions(EngineTask.java:2375)
    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:191)
    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
    at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:937)
    ... 39 more
Caused by: java.lang.ClassCastException: org.eclipse.birt.report.engine.content.impl.TableContent cannot be cast to java.lang.Comparable
    at java.util.TreeMap.compare(Unknown Source)
    at java.util.TreeMap.put(Unknown Source)
    at java.util.TreeSet.add(Unknown Source)
    at java.util.AbstractCollection.addAll(Unknown Source)
    at java.util.TreeSet.addAll(Unknown Source)
    at java.util.TreeSet.<init>(Unknown Source)
    at org.eclipse.birt.report.engine.executor.OnPageBreakLayoutPageHandle.doAddContent(OnPageBreakLayoutPageHandle.java:143)
    at org.eclipse.birt.report.engine.executor.OnPageBreakLayoutPageHandle.addContent(OnPageBreakLayoutPageHandle.java:135)
    at org.eclipse.birt.report.engine.executor.OnPageBreakLayoutPageHandle.access$0(OnPageBreakLayoutPageHandle.java:115)
    at org.eclipse.birt.report.engine.executor.OnPageBreakLayoutPageHandle$PageContentBuilder.startContent(OnPageBreakLayoutPageHandle.java:196)
    at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startContainer(ContentEmitterAdapter.java:136)
    at org.eclipse.birt.report.engine.emitter.ContentEmitterAdapter.startRow(ContentEmitterAdapter.java:115)
    at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.startRow(CompositeContentEmitter.java:298)
    at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEmitter.startRow(HTMLTableLayoutEmitter.java:613)
    at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.startContent(ContentEmitterUtil.java:56)
    at org.eclipse.birt.report.engine.layout.html.buffer.ContainerBufferNode.start(ContainerBufferNode.java:83)
    at org.eclipse.birt.report.engine.layout.html.buffer.ContainerBufferNode.start(ContainerBufferNode.java:79)
    at org.eclipse.birt.report.engine.layout.html.buffer.HTMLPageBuffer.startContent(HTMLPageBuffer.java:113)
    at org.eclipse.birt.report.engine.layout.html.buffer.TableBreakBuffer.startContent(TableBreakBuffer.java:287)
    at org.eclipse.birt.report.engine.layout.html.HTMLLeafItemLM.start(HTMLLeafItemLM.java:67)
    at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:139)
    at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
    at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
    at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
    at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
    at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
    at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.layoutChildren(HTMLTableBandLM.java:67)
    at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
    at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
    at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
    at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
    ... 41 more
Re: Runtime exception occures when write any code into onPageStart or onPageEnd evetns [message #1770602 is a reply to message #1736532] Mon, 14 August 2017 21:32 Go to previous messageGo to next message
PHILIP CHANG is currently offline PHILIP CHANGFriend
Hi Viktor,
I am seeing a very similar exception...Have you determined any resolution?
Philip
Caused by: java.lang.ClassCastException: org.eclipse.birt.report.engine.content.impl.ForeignContent incompatible with java.lang.Comparable
at java.util.TreeMap.compare(TreeMap.java:1200) ~[?:1.7.0]
at java.util.TreeMap.put(TreeMap.java:543) ~[?:1.7.0]
at java.util.TreeSet.add(TreeSet.java:267) ~[?:1.7.0]
at java.util.AbstractCollection.addAll(AbstractCollection.java:354) ~[?:1.7.0]
at java.util.TreeSet.addAll(TreeSet.java:324) ~[?:1.7.0]
at java.util.TreeSet.<init>(TreeSet.java:172) ~[?:1.7.0]
at org.eclipse.birt.report.engine.executor.OnPageBreakLayoutPageHandle.doAddContent(OnPageBreakLayoutPageHandle.java:143) ~[?:?]
Re: Runtime exception occures when write any code into onPageStart or onPageEnd evetns [message #1798826 is a reply to message #1770602] Mon, 26 November 2018 10:53 Go to previous message
Thirumal m is currently offline Thirumal mFriend
Same here. Found any answer ?
Previous Topic:Using console inside included BIRT scripts (initialize)
Next Topic:birt-runtime-4.8.0
Current Time: Mon Aug 19 05:58:06 GMT 2019
Powered by FUDForum. Page generated in 0.01465 seconds
