Home » Modeling » EMF » Delete
Delete [message #1736501] Wed, 29 June 2016 20:44 Go to next message
Alex Kravets is currently offline Alex KravetsFriend
Please delete
[Updated on: Thu, 30 June 2016 01:01]
Report message to a moderator
Re: Model element sort in a tree [message #1736525 is a reply to message #1736501] Thu, 30 June 2016 08:12 Go to previous messageGo to next message
I think that you are mistaken in thinking that EMF is doing anything
very clever or helpful.
EMF collections are all lists, so what you see is 'chronological'
addition order.
In the case of your example for which you provide no models, I suspect
that typeA/typeB/typeC are in different child features that are shown
in, I think, metamodel feature order, ie. inheritance+chronological
order wrt the metamodel edit session..
If the order is important to you, you should make it part of your
design, rather than relying on accidental EMF functionality.
For graphics, the order is often irrelevant, so you might prefer to
define your collections as not-ordered, deferring imposition of order
until some save / transformation activity benefits from repeatability.
Ed Willink
On 29/06/2016 21:44, Alex Kravets wrote:
> I have EMF model that roughly looks like this:
> root
> --- typeA.1
> --- typeA.2
> --- typeB.1
> --- typeC.1
> --- typeC.2
> --- typeC.3
> if I were to add another element of typeA.3, it would be positioned
> between typeA.2 and typeB.1 - this is out of the box behavior that EMF
> generated editor offers and it's correct. How is the correct order
> kept when I am adding new element?
> The reason I am asking is that I am writing a Graphiti editor that
> graphically represents my model differently. Right now when I add new
> element typeA.3, as in the example above, it would be positioned below
> typeC.3, which is not correct ordering of the elements (according to
> EMF model). I can add comparator to the List that is used by Graphiti
> to layout the components, but I rather if possible reuse mechanism by
> which TreeViewer in EMF keeps elements sorted correctly.
> Alex
Re: Model element sort in a tree [message #1736613 is a reply to message #1736525] Thu, 30 June 2016 14:59 Go to previous message
Thanks Ed,
I deleted the post because I realized that I was relying on Graphiti's List to display children whereas I should've been using EMF's List that has correct order and using that to display graphical parts. So this issue had to do with my particular case and not with EMF.
Previous Topic:Invalid thread access while updating UI
Next Topic:Managing dependencies between EMF resources.
Current Time: Wed Jul 28 14:11:09 GMT 2021
Powered by FUDForum. Page generated in 0.01628 seconds
