Home » Newcomers » Newcomers » MARS - CVS plugin configuration(How to enable CVS operations in MARS)
icon5.gif  MARS - CVS plugin configuration [message #1736500] Wed, 29 June 2016 20:21 Go to next message
William Harrelson is currently offline William HarrelsonFriend
Have been using CVS with Eclipse for years, just upgraded to MARS.
Ok, CVS not there, go get it.
I've managed to install the CVS plugin in Mars, and can connect to the repository and browse it the CVS perspective, but when I go into Project Properties and click on "CVS" I see: File not found: [directory name]\CVS\Entries.Static
I have an 'Entries' file, but no 'Entries.Static' file. Why would I have that, or what do I need to do.
All operations on the project such as 'Compare With'->'Latest from Repository' get "The chosen operation is not enabled"
How do I fix this?
Re: MARS - CVS plugin configuration [message #1736563 is a reply to message #1736500] Thu, 30 June 2016 11:10 Go to previous message
Hmm, well, when I checked the plugin (Help→Install New Software...
"Work with:" "The Eclipse Project Updates" option.
"Eclipse CVS Client" still showed. So I installed again, and now everything is working after a re-start.
Previous Topic:eclipse zip file extracting prob
Next Topic:Installer vs. usability at all
Current Time: Tue Nov 12 19:28:35 GMT 2019
Powered by FUDForum. Page generated in 0.03162 seconds
