Home » Modeling » EMF » Invalid thread access while updating UI
Invalid thread access while updating UI [message #1736432] |
Wed, 29 June 2016 12:05 |
Oleksiy Bulhakov Messages: 5 Registered: May 2016 |
In order to update UI after changes which were perfomed in model, I've implemented listener in my custom ItemProvider.
I've used this tutorial:
http://eclipsesource.com/blogs/2013/01/29/emf-itemprovider-magic/
To make everything work properly, I had to set setFireLabelUpdateNotifications(true) in my LabelProvider, which is a child of an AdapterFactoryLabelProvider. It seems like it works fine, by is this ok to do it, or maybe there are other ways to fire my listener?
After setting setFireLabelUpdateNotifications(true) in some cases I get "invalid thread access" SWTException. It happens, when notifications are fired from another thread (from a job in my case). Obviously, I have to run my code in UI thread, so I have to place Display.asyncExec(...) somewhere... Where should I place it?
If I place it in my ModelItemProviderAdapterFactory, in fireNotifyChanged(final Notification notification) method it solves the issue, but it seems to me like there has to be better solution.
If someone encountered this issue, could you please share your thoughts on the solution?
Thanks in advance.
[Updated on: Wed, 29 June 2016 12:17] Report message to a moderator
Re: Invalid thread access while updating UI [message #1736439 is a reply to message #1736432] |
Wed, 29 June 2016 12:17 |
Jonas Helming Messages: 699 Registered: July 2009 |
do you use databinding for updating the UI?
What are the cases in which you get the invalid thread Exceptions?
Best regards
Jonas
On 29.06.2016 14:05, Oleksiy Bulhakov wrote:
> 1) In order to update UI after changes which were perfomed in model,
> And to make everything work properly, I had to set
> setFireLabelUpdateNotifications(true); in my LabelProvider, which is a
> 2) After setting setFireLabelUpdateNotifications(true); in some cases I
> on the solution?
> Thanks in advance.
Re: Invalid thread access while updating UI [message #1736440 is a reply to message #1736432] |
Wed, 29 June 2016 12:22 |
Ed Merks Messages: 33140 Registered: July 2009 |
In generated editors normally notifications are wrapped and this
threading problem is handled by
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvider.notifyChanged(Notification).
> listener?
> Thanks in advance.
Ed Merks
Re: Invalid thread access while updating UI [message #1736466 is a reply to message #1736462] |
Wed, 29 June 2016 14:49 |
Yes, I would add logic at the central point where the notifications
arrive and are used to update the viewer, i.e., the label provider.
On 29.06.2016 10:21, Oleksiy Bulhakov wrote:
> My application uses databinding, as far as I understand it.
> The simplest case I have - my undo operation is wrapped into a job. So
> if I invoke my undo operation, I get these Invalid Thread Access
> exceptions.
> My problem occurs in LabelProvider, because it does not handle
> threading problem. Maybe I should implement my Display.asyncExec(...)
> in my LabelProvider notifyChanged(...) method?
> My LabelProvider is used by the CommandViewer. When I try to modify
> the model from the job, and notifications are fired, they eventually
> reach my viewer, and since job is being performed in separate thread,
> I get those exceptions.
Ed Merks
Current Time: Thu Apr 25 13:06:52 GMT 2024
Powered by FUDForum. Page generated in 0.03225 seconds
