Home » Modeling » EMF » [Xcore] Invariant code referencing XXXValidator constants
[Xcore] Invariant code referencing XXXValidator constants [message #1736413] Wed, 29 June 2016 10:32 Go to next message
Alexander Aumann is currently offline Alexander AumannFriend
For the following simplified model (MyModel) with an invariant operation:
class FancyNumber {
  String number;
  op boolean isValid(EDiagnosticChain diagnostics, Map<Object,Object> context) {
     if (!canParseAsNumber(number)) {
         EStructuralFeature feature = ....
         diagnostics.add(new BasicDiagnostic(Diagnostic.ERROR,
              MyModelValidtor.DIAGNOSTIC_SOURCE,
              MyModelValidator.FANCY_NUMBER__VALIDATE,
              "Not a number", #[this, feature]))
         false
     } else {
        true
Xcore cannot generate the model from a clean state anymore. It complains that MyModelValidator cannot be found (which is true, it needs to be generated first) and thus does not generate anything.
If I remove the reference to the validator, let xcore generate, and re-add the reference it works fine as the validtor has already been generated now.
Is there a better way of working around the issue than extracting the code for generating the diagnostic object into a static java helper class?
Kind regards,
Alexander
Re: [Xcore] Invariant code referencing XXXValidator constants [message #1736424 is a reply to message #1736413] Wed, 29 June 2016 11:36 Go to previous messageGo to next message
Alexander,
Yes, there appears to be a difficult problem. Recognizing that an
operation is an invariant involves looking at the signature. But JVM
inference involves two phases:
Phase 1 infers the shallow structure, i.e., it generates stubs for
all the classes that the generator will generate.
Phase 2 infers the deep structure, i.e., all the methods and fields
in those classes.
Linking/resolving of types happens between phase 1 and phase2. But
during phase 1 the inferrer needs to determine if a GenPackage has
constraints, i.e., whether a validator class will be generated, but it
can't know that until after phase 1 is finished.
I'm not sure how to fix that chicken-egg problem, but please open a
Bugzilla.
In the meantime, you can add an Ecore annotation to ensure that the
invariant operation is recognized as an invariant during phase 1. E.g.,
this example works:
package org.example.test
import org.eclipse.emf.ecore.EDiagnosticChain
import org.eclipse.emf.ecore.EMap
import org.example.test.util.TestValidator
class Example{
@Ecore(invariant="true")
EMap<Object,Object> context) {
val x = TestValidator.EXAMPLE__IS_VALID
true
Perhaps that's the only solution that will ever work, i.e., perhaps this
is a limitation.
> class FancyNumber {
> String number;
> context) {
> MyModelValidator.FANCY_NUMBER__VALIDATE, "Not a number",
> #[this, feature])) false
> } else {
> true
> generated now.
> class?
> Kind regards,
> Alexander
Ed Merks
Re: [Xcore] Invariant code referencing XXXValidator constants [message #1736430 is a reply to message #1736424] Wed, 29 June 2016 11:56 Go to previous messageGo to next message
Hi Ed
I hesitate to suggest that you have forgotten how genmodel works; helper
methods generate useful names of future literals without needing to
reflect. The only minor problem is that sometimes loading a stale
*Impl.java file fails as a consequence of serious errors. The
constraints can all be predicted from the "constraints" EAnnotation.
Ed Willink
On 29/06/2016 12:36, Ed Merks wrote:
> Alexander,
> in those classes.
> Bugzilla.
> E.g., this example works:
> class Example{
> true
> this is a limitation.
>> operation:
>> class FancyNumber {
>> String number;
>> context) {
>> } else {
>> true
>> generated now.
>> class?
>> Kind regards,
>> Alexander
Re: [Xcore] Invariant code referencing XXXValidator constants [message #1736431 is a reply to message #1736424] Wed, 29 June 2016 12:03 Go to previous message
Thanks Ed,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=496998
I did not include your reply in the bug yet, I don't know exactly which part is relevant to you for future reference.
I will try the annotation and report back to confirm the solution.
Previous Topic:[Xcore] Proposed way of adding adapters to new instances
Next Topic:Invalid thread access while updating UI
Current Time: Sat Jul 31 16:54:28 GMT 2021
Powered by FUDForum. Page generated in 0.01947 seconds
