Home » Modeling » M2T (model-to-text transformation) » [Acceleo] PackageNotFoundException(I'm trying to generate code from an instance of a metamodel)
[Acceleo] PackageNotFoundException [message #1736373] Wed, 29 June 2016 01:00 Go to next message
Higo Felipe is currently offline Higo FelipeFriend
Hello.
I'm working on a DSL metamodel now. After this metamodel, I ran an instance (.editor -> Run As -> Eclipse Application) and created on it a model and a Acceleo Project to code generation.
When I try to run the Acceleo application, I have, however, an error message:
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'hxxp://www.example.org/classdiagram' not found. (file:/C:/Users/Higo/runtime-EclipseApplication/exemplo/My.classdiagram, 2, 199)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:391)
	at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:356)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:475)
	at org.eclipse.acceleo.module.sample.main.Generate.<init>(Generate.java:90)
	at org.eclipse.acceleo.module.sample.main.Generate.main(Generate.java:144)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'hxxp://www.example.org/classdiagram' not found. (file:/C:/Users/Higo/runtime-EclipseApplication/exemplo/My.classdiagram, 2, 199)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2625)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2458)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1335)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1504)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
	at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	... 6 more
Since I have no experience with Acceleo, I can not precisely identify a cause for this error message. How could I fix it?
Higo.
Re: [Acceleo] PackageNotFoundException [message #1736593 is a reply to message #1736373] Thu, 30 June 2016 14:00 Go to previous messageGo to next message
Laurent Goubet is currently offline Laurent GoubetFriend
Please look at the comments in the generated java launcher beside your main template (org.eclipse.acceleo.module.sample.main.Generate.java) for an example of how to register your metamodels. You'll need a direct dependency from your generator project to the project that hosts your your metamodel as well for it to work properly.
See also the answer on this earlier thread.
Please keep us informed if you still don't manage to get it running.
Laurent Goubet
Obeo
Re: [Acceleo] PackageNotFoundException [message #1736843 is a reply to message #1736593] Sat, 02 July 2016 21:23 Go to previous message
Thank you for the answer, and sorry for the late response.
I already managed to work around the issue. The application is running now.
H.
Previous Topic:[Acceleo] Custom Acceleo metamodel
Next Topic:[Acceleo 3] Multiple metamodels
Current Time: Mon Oct 18 02:46:42 GMT 2021
Powered by FUDForum. Page generated in 0.02477 seconds
